Question about a Shelf Stereo System
Questions or Comments: I had a quick question about a stereo system I was thinking about buying. The system in question is the Sony - 560W 5-Disc Mini Hi-Fi Stereo System with Dual Cassette Decks - Black Model: LBTZX6 and my question is can I hook my laptop or other device such as an ipod up to it. In the features it says it plays mp3s but im curious as to if it will directly connect to my laptop so that I may choose music on my laptop to play through the stereo system. If so how might I do that, I would require a chord of some sort Im sure; but if you could also tell me what chord I would need it would be much appreciated. Thank you very much.
Here is a link to the specs if that would assist you.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11038890
  • Anonymous Dec 21, 2008
    I am trying to connect my ipod to play through this system and can't seem to switch the function to AUX. The tuner only switches between AM/FM and back to the CD function. There are no other options so i'm wondering if connecting my ipod into this system as I do on other stereos is possible.
    President:
  • 624 Answers
It appears that this stereo does have audio input on it. It has a front A/V input that you could use for your laptop. You need a mini-stereo (3.5 mm) jack to RCA cord to connect your laptop with it. On the laptop you should have an audio output that is normally a green connector jack and that is where you connect the laptop. The mini-stereo jack looks like a headphone jack. You can get the mini-stereo to RCA cord at Radio Shack or Best buy. The RCA end would connect to the input of the Stereo on the red and white RCA inputs. Then you can play music on the laptop and listen to it on the stereo, just make sure the stereo is set to the proper function (whatever you connected the laptop to) and the audio of the laptop is turned up to a sufficient volume level (max volume is OK). It is very easy to connect the two together. I hope this makes sense to you, if you want me to explain it better just let me know.
Posted on Sep 06, 2008
  • 10,594 Answers
You can use any analog Audio input out of 3 at rear of this system to listen laptop sound. Audio Cord is required to hook up and its look like red-white RCA pins at one end and other end is like headphone stereo jack for laptop. Audio Cord is available at Sony Part Center.
Hope above info will help you.
Looking to buy a "6CD stereo shelf system 500 Watts?
Consider first a separate system. For if one part of the shelf system fails you have to buy everything. If the CD say on a separate system fails you buy just one CD player. Separate systems have also much better sound quality also.
Oct 11, 2015 | Audio Players & Recorders
Cd stereo says no disc
The player mechanism may have failed.
Sep 08, 2014 | Emerson EM-MS9700 6 CD-Changer stereo...
Is there any good record players for under 100 pounds? (UK ONLY)
A brand that has a solid reputation but may be hard to find in your area is technics. I would think you could find one to fit in that price range. You could for sure find a Pioneer in that price range and they are not bad at all. These are vintage, not new, I am talking about but they will outperform most consumer made ones of today.
Nov 12, 2012 | Audio Players & Recorders
Stereo
You will need to change the audio output ic in the stereo to reset it.
Mar 07, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
When i turn off my stereo, it turns back on in three seconds.i don't have the remote anymore. how do i get the stereo to stay turned off.i pushed the AUX button-but that didn't do anything and my step...
You can buy a universal remote that should work with your stereo - but it may not solve the problem.
If the latching system that hols the OFF setting is broken the remote software will probably not overide it,
Ask your step father to put his hand in his pocket to help you get a new/better one - everything changes in time!
Feb 26, 2011 | Panasonic SC-AK100 CD Shelf System
How to play my ipod through this stereo
USER GUIDE
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
Questions about the ELECTRO BRAND NOSTALGIC STEREO 9230CGB....
They run between 15 and 20 Watts.
Have small speakers. Recommend for lower volume listening.
Jun 02, 2009 | Electro Brand Nostalgic Stereo CD Music...
Panasonic SA AK75 stereo system with 50+1 cd changer
pull the fuse in the back and it should reset the stereo
Oct 30, 2008 | Panasonic SC-AK75 Shelf System
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Need help
I have this stereo and so do 2 friends. We've all had the same problem but I turned my stereo into a certified repair shop and they fixed the problem. I think something on one of the PCB's inside the unit misaligned. I didn't pay more than $50 for the repair. There was no major repair they told me.
Jul 19, 2007 | JVC HXD7 5-disc Home Stereo Theater System...
230 people viewed this question
 Grubhead
Grubhead
