Question about Emerson Home Audio System with 5 CD Changer (MS9923TT) Shelf System
Speaker problem only when playing records
Only the left speaker operates when playing records...otherwise both speakers work fine.
    Champion:
  • 277 Answers
Hi its not the system.... your recorder is set on left good luck
Posted on Feb 26, 2006
I have Teac SL-D80 radio, CD player. One of its speakersLeftdoesn't, work.How to fix it? replace the speaker or wire?Thank you!
Unplug unit.
Open casing.
Look for loose wiring connector, otherwise:
Temporarily swap left and right speakers.
Plug in and play a continuous recorded tone of about 50Hz-440Hz.
Play with maximum volume to get a decent voltage reading.
If LEFT CH now works then L speaker is faulty.
If RIGHT CH now works then L amplifier is faulty.
Electrical test (needs a meter with Volts and Resistance).
With speaker still connected test audio (AC V) signal on working right speaker terminals.
Now check left Channel at amplifier board if possible, and at speaker terminals.
If no V unplug speaker wires if possible at board then test across board L+ and L- output pins.
Still nothing means amp is faulty.
Test continuity of speaker wires end-to-end. Each wire should be 0 ohms or close to zero. The continuity buzzer function can also be used for this.
With amplifier off and unplugged, remove speaker-connector from board or cut live speaker wire or unplug lug at speaker, whichever is easier. With one wire apart from the amplifier, test the loudspeaker ohms.
Should be in the range of about 4-8 ohms.
Most speakers have the rating screen-printed on the voice-coil magnet housing.
If ohms reading is way too low, say 0-1 ohm it has a short and is damaged.
If ohms reading is way too high, say several Meg-ohms, it has a coil break and is damaged.
Carefully join/tape any cut wires if applicable, renew speaker if faulty with same size and rating, re-test then re-assemble.
Dec 18, 2017 | Cars & Trucks
How can I make a computer speaker work with my phone? I only have the Left speaker but it has a regular headphone plug. When I plug it in the music plays for a couple seconds.
Yes, I use computer speakers with my phone all the time BUT, if you just have the one unpowered speaker it is not going to work well if at all. The problem is the phone is not putting out enough power to drive the speaker. If you connect it up to the full set WITH the amplifier, it should work fine.
Feb 12, 2017 | The Audio Players & Recorders
I just bought Creative Inspire M4500 (4.1) speakers. I connected all the four speakers the way they are supposed to. Now I see that only two speakers are working. When I conduct the audio test, all the...
some cd has only 2 channel sound. which is called stereophonic sound. when u play these cds the audio will be heard only on front left & right speakers. in order to get sound in all four speakers u need a 4.1 channel sound dvd/cd. see on the label of cd/dvd if 4.1 ch. sound is recorded on it.
Sep 03, 2011 | Computers & Internet
NO SOUND FROM SUBWOOFER ~ RIGHT AND LEFT SPEAKER OK MY SOUND CARD IS SOUND BLASTER 5.1 MY SOFTWARE IS MICROSOFT XP
Are you playing your audio(playback) which has been recorded for 5.1 speaker system? If not then you cant make all the speakers work since those heads do not carry any signal. Remember plugging stereo jack on a stereo cassette/tape player where the recording is done mono----- only one Chanel will have output unless you adjust the head manually. Here there is no scope for that, so essentially the recording has to done for 5.1 output otherwise you will get the same output as now...sodeep
Mar 21, 2009 | Logitech X-230 Computer Speakers
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Dec 27, 2008 | Dell Inspiron 1521 Laptop
Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Jan 13, 2008 | Logitech X-530 Computer Speakers
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
SPEAKERS TO DMR E55 DVD RECORDER
Using a receiver to operate speakers?...accordianman
Nov 08, 2007 | Panasonic DMR-E55 DVD Recorder
67 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
