Question about Poulan 12a Elec Blower/Vacuum
Poulan pro elec blower/vacuum
The starter rope pulled out of the unit what do I do?
  • 163 Answers
Remove the starter housing, usually only 3 or 4 bolts or screws. on the inside should be a large white or black wheel, hold the outer case with one hand and rotate the wheel counter-clockwise with the other as many times as can without force. on the inside of the wheel should be a small hole, rotate the wheel to line it up with rope guide hole on the outer case/housing. use a nail or small screwdriver to help hold in place. feed the start rope through the 2 holes and tie a knot at the end, single or double depending on the size of the hole. if the end of the rope is frayed, use lighter to melt and twist to a point to make it easier to handle. when reassembling you may need to jiggle the handle for realignment. it works on an inner spring coil tensioner system, so if the cable has no tension when rotated or doesn't recoil back, the starter assembly will need to be replaced.
Posted on Nov 30, 2008
Fuel lines poulan bvm200vs gas blower
You need to split the entire unit to get to the fuel tank. Remove carb, remove exhaust, and remove right side of plastic enclosure. Check the cylinder to make sure it is tight, these units are notorious for the cylinder coming loose. Remove the tank and install your new fuel lines, leave them long then trim to fit once reassembled. Check to be sure the isolator mounts and starter rope ferrule are in place when reassembling
Jul 17, 2012 | Poulan Pro Gas BlowerVacuum ()
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Can't pull starter cord
Here are some suggestions: Rope is bound on the pulley. Engine is locked up. Debris in the impeller housing. Flooded, excessive fuel in the combustion chamber. These are just a few. Hope it gets you in the right direction.
Feb 21, 2011 | Poulan Pro Super Blowervacuum
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
The pull rope came out of my poulan pro 200vs
Get a preplacement recoil mechanism at your dealer.
May 16, 2010 | Poulan Pro Gas BlowerVacuum ()
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Poulan rope broke and pulled out of unit. How is
I have manually fixed these starters before and it is really more trouble than it is worth (and not one unit I fixed ever worked exactly the same afterwards). I would suggest taking it to your local small engine repair shop. They have both the patience and the tools to do the job right and the cost is well worth it--trust me!
Oct 20, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Feb 13, 2009 | Poulan 12a Elec Blower/Vacuum
Poulan 12a Elec Blower/Vacuum Logo
104 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
