Question about AsanteTalk - Ethernet to LocalTalk Adapter Transceiver
Laserwriter 4/600 to G5 via asante talk
Can't find printer, need help. thanks.
  • jackchro Dec 16, 2008
    also have a G5 and Asantetalk. The computer "sees" the printer, but when I try to print I get a message that says that the printer is busy - even though there is nothing else in the queue and the printer light does not blink. Appletalk does not see the printer, and LPD is what I am trying at this point. no luck so far - does anyone know how to get this to work? thanks.
  • Anonymous May 20, 2009
    Have been struggling with the same problem for quite awhile, and this solution worked perfectly for us. Thanks!
  • 5 Answers
The wonderful Asante tech support people in San Jose, CA, talked me through this fix last week:
This is for system 10.5.x.
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully. I had no further problems.
Posted on Jan 17, 2009
Apple Laserwriter 8500 paper light out, when there is paper in the cassette. Not blinking. Solid yellow.
make sure the usb lead connection is secure
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X
this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 06, 2011 | Apple LaserWriter 8500 Printer
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Apple 16/600 Laserwriter reports out of paper but its not
It's the sensor from tray fault. Try to blow with air spray to sensor, maybe is dirt with paper dust and need clean.
All the best and Happy New Year !
Dec 29, 2017 | Apple LaserWriter 12/640 PS Plus Printer
Laser writer select 360 to Mac OS X 10.4.11 via AsanteTalk
You should phone the Asante tech support people in San Jose, CA, who will talk you through the fix for free. I lost my printer-MacPro connection, the other day, and everything works fine now, thanks to their advice.
I'm running 10.5.x and no WiFi so the fix may not be the same, but it was just a matter of sort of re-booting the Asante box. Here was my fix, if that helps:
Dec 21, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
12/640 Laserwriter - driver needed.
I had the same problem when I got a new computer with Vista. I just went through the available 600 DPI printer drivers until I found one that worked ok with the 12/640 printer. The driver I used was the Samsung 6000 PS. I have had no problems with it.
Nov 19, 2008 | Apple LaserWriter 12/640 PS Plus Printer
Asant? Talk compatibility with Mac OS 10.5.5
This is for system 10.5.x:
Nov 13, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Same issue after power loss...
The wonderful Asante tech support people talked me through this fix (for free), just the other day.
Jun 25, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Asante Talk doesn't see printer after power failure
The Asante tech support people in San Jose, CA, talked me through this fix, and I've had no further problems!
9. Everything should communicate beautifully now.
Mar 09, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
Asante talk after power failure
From the manual, it suggests: 1) shut everything down 2) turn on the peripherals, let them fully start 3) For multiple computer systems, turn them on 4) Power up the Asante talk bridge.
Dec 02, 2007 | AsanteTalk - Ethernet to LocalTalk Adapter...
AsanteTalk - Ethernet to LocalTalk Adapter Transceiver Logo
433 people viewed this question
Top Asante Computers & Internet Experts
David Payne
David Payne
Are you an Asante Computer and Internet Expert? Answer questions, earn points and help others
