Question about Kenmore 24032\24036 Top Load Washer
Kenmore Elite How do you fix if my washer can't spin backward and forward but still spin when it rinse. Thanks alot
  • 116 Answers
Luckdan209
your washer is not agitating -
1. Check that water level switch works
2. Does it attempt to move when selected? Washer timer contacts may be burnt.
3. Your motor could be bad - washing spinning different ckts
Regards
Posted on Sep 07, 2008
My Kenmore Elite washer starting making a bad noise during rinse/spin cycle and now wont drain??
Most washers have a gearbox that has about 15 gears in them it's the heart of the whole process backwards fast slow is all controlled by these gears my whirlpool box was off white took total dis assembly would cost more to fix than replace... so I opened box the hard way and found millions of tiny perfect .5mm cylinders as if from penny's and nickles over the years cool to lok at but devastating on plastic gears....be prepared to go used washer shopping...~~~SC
Sep 25, 2014 | Washing Machines
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
