Question about Pioneer DV-C302D DVD Player
BUSTED FUSE Upon using my dv-c302d, found out it can't power up. I already checked the power cord and the electrical outlet and found okay. I tried to checked the DVD power supply and found out the fuse is already busted. What is the possible cause of this problem? I've been using my DVD player for almost 5 years now and this is the first time got problem. hope you can help me.
    Scholar:
  • 48 Answers
A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
Posted on Jan 02, 2006
SOURCE:
No power to TV
First thing to do if your television have no power is check the power outlet,then the AC cord continuity.If the ac cord have power supply,check the fuse,maybe the fuse is busted.Its is located at the power supply.So try to remove and open the back cover of your TV and look the power supply and replace the fuse if busted.Replace same value of fuse.Try this procedure,hope it will help you.Thanks..
Aug 26, 2011 | Panasonic Televison & Video
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
HAS NO POWER AT ALL
If your television is totaly no power,first step to do is to check the power outlet if there's a power output.Then check the power cord,if good,the problem is inside the television.Maybe the fuse is busted.So remove the back cover of the television and find or look the power supply.The fuse is located at the power supply.Replace same amphere of fuse if busted or open.Try to power on if you already replace fuse.Thanks...
Aug 21, 2011 | Hitachi 42HDS69 42 in. Plasma Television
My sanyo model CLT2054 will not power up
Hi Please check the fuse of your television.It is located at the power supply near the ac cord just fallow the ac cord in to the board.Unplug first the your TV to avoid electric shock.Remove the back cover to see the fuse of your TV,then check if the fuse is busted.Replace the same value or amphere of fuse.Then try to power again.Thank u..
Jul 12, 2011 | Sanyo Televison & Video
My 20^ iMac do not turn on. Help!!
Relax. Check the cord if it is connected properly. It might be that the plug is loosed, some wires are open or the outlet is defective. Try to plug to other outlet. If the problem persists. Look at the power diode if it is off the power supply is defective. Listen to the fan in the power supply inside the casing if it is working. If it is not, then the fuse is busted. If you can take the busted fuse out then ok otherwise, you the service of the technician. If you have AVR connected to it, check the AVR if it is working, check if the switch is on, the lights on etc, same thing also with UPS. Contact me then if the solutions are not working.
Jan 31, 2011 | Apple Computers & Internet
My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Sep 27, 2009 | Televison & Video
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
The toaster does not heat and it's only 6 mos. old.
1. check outlet where you plug in your toaster with lamp or vacuum.
jiggle plug of lamp or vacuum while plugged in to check for bad outlet.
if lamp or vacuum do not work, check breaker panel/fuse box for tripped breaker/blown fuse.
if breaker/fuse okay, replace outlet.
if lamp or vacuum work okay, go to next step
2. plug toaster back into outlet, jiggle plug, then jiggle cord at plug, then jiggle cord at toaster.
this checks for intermittent power cord.
if cord okay, check that the toaster lever or toast basket are not blocked from going completely down.
might be a bit of bread, muffin, bagel that blocks the basket.
if all okay, you need other solutions.....
Jul 09, 2009 | Back to Basics Kitchen Appliances - Others
Tv wont turn on
Just try to hold the power button while pressing for 15 seconds .If still not powering up then that is the time to check the fuse maybe the fuse is busted already,this is the common problem when you already secure all the corde and wall socket for electricity is there still your tv is not turn on.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 02, 2008 | HP PSC 2110 Color Printer
Pioneer DV-C302D DVD Player Logo
291 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
