Question about Dryers
Noisy dryer Kenmore Elite 70892 (gas-LP)..
We have a Kenmore Elite King Size Dryer (gas-LP) and I am trying to figure out how to access the inside to see if it needs cleaning or the rollers or some other part needs replacing.  It makes a buzzing noise while running that stops when the dryer stops (a second sound - a roller sound keeps going until the drum stops).
  • 1 more comment
  • carlene222 Sep 06, 2008
    I recently asked about a Maytag dryer, but was mistaken about the make.
  • carlene222 Sep 09, 2008
    Thanks I'll try that this weekend.   Our Kenmore washer is starting to sound noisier.  Got any ideas on that? :)
  • Anonymous Jan 12, 2009
    replacing support rollers in dryer
  • 1,543 Answers
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Posted on Sep 07, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 10, 2008
    Washers starting to sound noisy are usually not good. (ie: expensive repair issues come to mind) You don't say how old your machines are, but are having trouble with both. Average life of a washer is about 9 years, a touch more for a dryer. It may be time to consider investing in a new set. Consumer reports rates LG front loaders the best, and I'd agree, but you don't need to get the top of the line LG's. All the LG's use a direct drive motor with a 7 year warranty on the motor, and have no belts, pulleys, transmission or clutch. Water use is about 12 gallons (vs. over 40 for a top loader) and spin speeds are 1000 RPM or more (vs. 550 for top loaders). Look for a small retailer who also does their own service (try http://us.lgservice.com/index_b2c.jsp) (they will still compete on price). They know the products better and can help with any post sales issues you may ever encounter, and most likely will be able to deliver sooner and when you want it, not when they want to bring it out. The big guys,..... ha, ha,...well, let's just say you won't get much help from them. Note: If you replace your washer with a front loading machine, remember to use no more than one tablespoon of HE detergent and one teaspoon of fabric softener per load !
Have Kenmore elite dryer. How do you get into it to convert from LP to natural gas?
most require a kit to change from 1 type gas to the other . they have to come in thru the back someplace
Feb 09, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
I have a kenmore elite King size Quiet Pak II dryer that won't stay on unless i hold the button down and even when i do that the dryer is not getting hot.. Any suggestions would be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
I have a Kenmore Elite heavy duty king size capacity electric dryer model 110.63032101. When I push the button to start the dryer all I hear is a clicking sound inside the dryer somewhere and the dryer...
heatman101
Nov 29, 2010 | Dryers
Trying to find kenmore elite heavy duty king sizecapacty plus ultraquite pac gas clothes dryer mod#11o72082100
It is no longer produced. Try eBay or craigslist?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 74602 Gas Dryer
Coins stuck inside dryer fins
raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Nov 30, 2008 | Kenmore 74602 Gas Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Kenmore Frigidare Front load dryer 417.93042203
The front panel clips usually hold by friction. Just pull gently on the upper corners and it should hinge down.
Aug 08, 2008 | Kenmore 73952 Gas Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
