Question about Pioneer Car Audio & Video
Pioneer DEH P3000R face off car audio. Display back light has gone. Display can be read but it is very faint.
CAYPIANAN
  • 227 Answers
SOURCE: PIONEER DEH-P77DH DETACHABLE FACE WILL ONLY
hello, i am affraid that you have a deffective ribbon cable,that is a common problem on those car radios
caypianan@yahoo.com
Posted on Oct 03, 2008
SOURCE: My Pioneer DEH-P645 faceplate display is FAINT
The circuit board is broken.
I was trying to find out about setting the display dimmer option. I found someone that had a manual and was told to set/reset the "dimmer on/off" by pressing the function button repeatedly while the unit is powered off. When dimmer showed on the faceplate press up or down to set or reset the dimmer option. This was done in a dark closet as the display was so dim. Anyway, setting dimmer to on/off made no difference in the brightness of the display. Oh well. . . BTW, I found that the manual is not a free download and can cost between $18 - $40 on the internet - geeeeee whiz, Pioneer is not a user friendly company.
Posted on Mar 07, 2009
XSdB
  • 80 Answers
SOURCE: display back light problem
There are several baclkight bulbs (or may be leds)
Either the bulbs are burn out, or there may be a crack in faceplate PCB that is stopping the power from getting to the backlights. If all other buttons/functions work ok, then suspect burnt out bulbs. Expecially if there's a lot of use on the unit. The bulbs can be replaced by a repiar center, or by you if you have the skills.
Posted on Jun 12, 2009
mikopeco
  • 23 Answers
SOURCE: Hello, I need to know the
If this helps you then please help my rating,voting for me would be great too thanks.
Black - Ground
Blue - Power Antenna / Control for an AMP
Orange - Constant 12 Volts
Red - 12 Volts when the ignition is on, 0 Volts when it's off
[Speakers]
[Front]
Gray - Front Right Positive
Gray Black - Front Right Negative
Green - Front Left Positive
Green Black - Front Left Negative
[Rear]
Gray Red - Right Rear Positive
Black Gray - Right Rear Negative
Green red - Left Rear Positive
Black Green - Left Rear Negative
Posted on Nov 15, 2010
  • 1566 Answers
SOURCE: i am looking for the
Hello there,
Please click on this link to download the user manual:
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/DEH-P7450MP-_E
Posted on Dec 12, 2010
PLZ SOS... No reading of channels or writing lights up on face??
you probably have burned out bulbs behind the display. unless you are good at desoldering and soldering, i would suggest you have them replaced professionally.
Jul 26, 2010 | Pioneer DEH-445
Pioneer deh-p6300 does not elluminate when the
try using a qtip and rubbing alcohol or a pencil eraser to clean the contacts of the face and subpanel.
Jun 20, 2010 | Pioneer DEH-P6300 CD Player
How to reset my DEH-P5000UB, because my display turned off, weird
Re:"everyother light turns on the faceplate but the display is off"
That means that the unit is either faulty, or one of the two powered lines required had not been connected.
The unit is reset by simply disconnecting the connector at the back.
This will not help in fixing the problem.
Ensure that unit is wired properly. Use a voltmeter to test wiring.
Here installation manual with proper wiring.
Here also the owner manual.
May 26, 2010 | Pioneer DEH-P5000UB Car CD/ MP3 Player
Where is the reset button of DEH-3050mp?
Normally they are under the face plate GL
Jun 09, 2009 | Pioneer DEH-1900MP CD Player
OEL Display not Working on my Pioneer DEH-P7800MP
go to ebay.com search for (deh-p7800mp ribbon) face paate ribbon is probably bad i got one fixed it right up.
Jun 01, 2009 | Pioneer DEH-P7800MP
Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Mar 24, 2009 | Pioneer DEH-P7800MP
Mar 06, 2009 | Pioneer DEH-P645 CD Changer
PIONEER DEH-P7700MP/P770MP CD/MP3 Faceplate
do you want the detachable face or the case to hold the detachable face?
Here is the detachable face at the Pioneer site:
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Here is the case for the detachable face:
http://parts.pioneerelectronics.com/part.asp?productNum=CXB3520
You might find the face, or even the whole radio with face cheaper on ebay.
Jun 20, 2008 | Car Audio & Video
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
May 13, 2008 | Pioneer DEH-P840MP CD Player
Car Audio & Video Logo
90 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
