Question about HP PSC 2355 All-In-One InkJet Printer
Scanning capabilities are gone
Error message appears "Need to install or run HP software". Can't locate original CD with installation package. Have attempted to load new drivers from internet, but to no avail. I cannot use the scanner and get the same error mesage on the LCD screen"You need to install or run HP software for this feature." I have re-instlled 3 time and still it does not scan. HELP!
  • 2,071 Answers
Just click below for the troubleshooting;
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00896190&dlc=en&product=422000
Hope it may helps;
Regards,
VOTIT
Posted on Sep 17, 2008
    Master:
  • 441 Answers
Try to uninstall the drivers of the printer and then download the software and drivers here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=422000&lc=en&cc=us&dlc=en
Select the Operating system first then download the software and drivers /no network support.
After that if you want to scan you need to run the software that you have installed.
Hope that works.
    Genius:
  • 1,011 Answers
Dear,
didn't you scanned your hand the other time?
Maybe you should try scanning from the computer instead of pressing the button. May be it needs the HP software running together as you hit the button
regards,
dont rate it until satisfied
    Sergeant:
  • 264 Answers
First of all i would like to tell you that there is a difference between the Drivers and the Software.
Click here to download the software.
You need to select the option to download as
"HP Full Feature software/driver: No Network Support"
You would actually see the Icon on your computer as "HP Director" which will enable to use the scanning option.
While installing the software make sure that you have unplugged the scanner. You need to plug it in when it will try to detect the same during the software installation.
Once done you should be able to scan without any issues.
Posted on Sep 06, 2008
  • 1,031 Answers
You can download the genuine drivers from the hp web site
put the make and model of your printer .disable all all antivirus arunning before installation
  • Starnley Johnwells
    Starnley Johnwells Sep 06, 2008
    if after the problem still continues after proper installation then its a hardware problem then you check the data cable that runs from the scanner to the printer board
  • HP Master
  • 6,487 Answers
Go to devcie manager and check if the scanner is installed properly there..
Right click on MYcomputer>Properties>Hardware tab>Device manager then look there for the scanner I'm sufre its there but not working properly, so if see the scaner there wih a yellow exclamation mark just right click on it then install or update driver then manually look for the scanner driver that you have downloaded and after that it should work fine already.....
Hope that helps.......
    Master:
  • 638 Answers
Orignal cd is necessary .as because the orignal cd software only contains the scanner properties to load and the interner version only supports the printer version.
you call a technician at your place because any local computer technician will have this sofware which you require .
it will not cost u more then a service charge as nothing is to be repaired in the printer.
thanks.
please do rate the solution
    Problem Solver:
  • 53 Answers
  • HP Master
  • 13,433 Answers
Hey,
the drivers and software are available on the hp page, let me get you the correct ones, which windows are you using?
Thanks,
Ekse
  • Ekse Sep 06, 2008
    Hey again,
    you can get the software from here, I recommend the full feature package.
    http://h10025.www1.hp.com/ewfrf/wc/softw...&
    also as this is a all in one, you can try a semi full reset:
    Note:
    A semi-full reset will do the following:
    The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
    2. Then, press and hold # and 6 while plugging in the power cord.
    Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
I currently have an issue with scanning to my PC, on the printer detailed Below
I suspect half a file may be missing.
Try reinstalling the printer software.
Mar 06, 2017 | HEWLETT-PACKARD Photosmart C4485 , Copier...
F380 printer will not SCAN - keeps giving error message
Do you have original CD with you? if not down load the full feature drivers from hp web site. Un install the drivers, re-install once again..verify your driver CD supports the OS what you are using?..
Feb 03, 2012 | HP DeskJet F380 All-In-One Printer
Usb error
To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Jul 23, 2010 | HP LaserJet P2015 Printer
Error message "can,t find installation package scan.msi"
If you are getting this message while installing the software from the CD, Try to download the latest updated Software for your Operating from the HP's support website (support.hp.com),Just Enter the product number in the box provided and click on Software and download. Select your operating system and download the Driver software for your product. Save the software on you Desktop and try to install it from the Downloaded File.
Hope this solution is helpful to you. Please revert for any further assistance.
Thank you for choosing Fixya
Feb 09, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hp c6380 scanner issues
Contact HP for Care at 1-800-585-2494.
Jan 19, 2010 | HP Photosmart C6380 All-In-One InkJet...
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
Sep 07, 2009 | Office Equipment & Supplies
Photo smart 2610 all in one scanner will not scan
hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Jan 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Error 2738 when attempting to install HP F4180 printer software
Hi Stargateforg,
Try the solution from HP.
Solution one: Restart the computer
  1. Turn off the product.
  2. Restart the computer.
  3. Turn on the product.
  4. Use the HP software CD or the downloaded software file to install the HP Software.
Solution two: Register VBSCRIPT.DLL
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
  8. Use the HP software CD or the downloaded software file to install the HP Software.
Solution three: Download and install the latest version of the software
  1. Click here to go to the software download page on the HP Web site.
  2. Type the product model name in the text box and click the gray arrow button.
  3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
  4. Under the Drivers section, click Full Feature Software and Drivers .
  5. Follow the on-screen instructions to download and install the HP software.
Solution four: Custom Install Use Custom Install to install the basic print drivers only.
  1. Use the HP software CD or the downloaded software file to start installing the HP Software.
  2. When prompted, click Custom Install .
  3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
  4. Follow the on-screen instructions to install the basic print drivers.
Dec 22, 2008 | HP Office Equipment & Supplies
Picture Package
"PPMenuUpdateUS" is this an update or the primary installer. check it, I think u need the original exe file not an update.
Nov 02, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
HP Officejet 7310xi All-in-one Scanner feature doesn't work
Dear WPEARL ,
you have to re-install the driver for your Officejet.Its A driver's problem . maybe your Scanner driver's file is wanished or crroupt.
Cheerup and Be Happy Always
Mar 04, 2008 | HP Officejet 7310 All-In-One Printer
HP PSC 2355 All-In-One InkJet Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
