Question about Kenmore 19606 Computerized Sewing Machine
Error E1 My sewing machine suddenly displays message "Error E1" and will not respond.
3 Suggested Answers
SOURCE: E1 Error
After spending many hours on the phone with Sears, someone finally gave the manufacturer's phone number (1-877-739-4648)! Their help desk told me that an E1 error usually means that a fuse needs to be replaced. The fuse is covered under the 2 year electrical warranty. They said I should take the machine to a Sears Service Center to get it repaired. Go luck. I am completely frustrated with the Sears website and the salespeople who want to help, but can't because they haven't been trained on the machines!
Posted on Jul 05, 2006
SOURCE: E1 Error
check the solution what I already wrote.
Posted on Dec 27, 2006
SOURCE: E1 error
I was getting the E1 error message. I was told that the fuse had to be switched from the 2.5 amp that is has to a 3.5 amp. they did not recall the machine because of the low cost $2.99. I just received my fuse in the mail. I'm going to try to change it out myself.
Posted on Jan 23, 2009
0 characters
1 Points
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
Feb 14, 2016 | Sewing Machines
E1 Error
consult your manual or take it to a sewing machine dealer in your area.
Aug 08, 2014 | Janome Sewing Machines
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Kenmore 19233 Computerized Sewing Machine
E1 error message is a blown fuse problem.
Check out this site it shows you how to fix it
Feb 27, 2010 | Kenmore 19233 Computerized Sewing Machine
Error message #1
I had the same problem. It was plug ed into an extension cord as soon as i plug-ed it into the wall socket presto it works. I sure hope your problem is this easy.
Jun 20, 2008 | Janome Memory Craft 5700
E1 error code.
The pressure foot was up instead of down when I tried to run the machine without sewing something.
Feb 29, 2008 | Brother ES2000 Computerized Sewing Machine
E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Jun 16, 2006 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19606 Computerized Sewing Machine Logo
43 people viewed this question
Top Kenmore Sewing Machines Experts
Bargain Box
Bargain Box
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
