Question about Whirlpool LSR6334LQ Top Load Washer
Waher wont spin
Everything is set but when the water is done filling, nothing happens. You close the top and it doesnt start to spin. It works sometimes but most of the time you have to slam the top 50 times for it to go. What is the solution to this problem?
  • Whirlpool Master
  • 3,361 Answers
Replace the lid switch.
Posted on Apr 21, 2009
My washer wont turn on at all, wont fill up,spin or rinse on any setting
it sounds to me the lid switch problem. when it fails nothing works on some models
Dec 27, 2015 | Westinghouse WWS833ES Super Capacity Top...
Fisher & paykel smart drive 601, power to board, won't fill
If it isn/t doing anything at all it could be a faulty start switch on the display panel. Also make sure you can hear an audible click when you open and close the lid. The lid switch on a 601 is actuated on the right hand back of lid adjust as required. Hope this helps.
Oct 20, 2009 | Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Washer wont fill run or spin where is the best place to start looking
if it doesnt fill, nothing else will happen. check water supply (hoses, tap and filter screens) if all is well next is the waterpump is fried, not to expensive a part
Jun 15, 2009 | Whirlpool Washing Machines
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Whirlpool LSR6334LQ Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
