Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF440 Repalce Door Seal
How do i get the front panel off to get to the door seal
  • paulm1835 Sep 07, 2008
    hi i have same problem need to replace door seal on hotpoint aquarius wf 440 please help
  • 1,462 Answers
No need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Posted on Sep 07, 2008
Replace door seal
its quite easy on this machine,you can view a video on or remove front panel ,seven screws 4 top 3 bottom unclip wire on seal at front seal has two large clips to secure one outer and one inner, I find it best once the front panel is loose to unscrew the door interlock to fully remove cover once this is done you can see the workings and the exposed seal good luck.
Nov 02, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
to change the door seal you have to take the front boot ring off fold the door boot into the drum and undo the retaining clip around the door seals inner drum you can get a screwdriver in from the top a bit tricky but its the only way as the front is riveted on and wont come off like the older machines
Dec 08, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door seal
switch off from mains
remove outer clamp holding door boot to cabinet and peel off door boot.
remove work top
there is a clamp holding door boot to tub. undo clamp and pull door boot away
lubricate slot in door boot that goes on to the lip of the tub using washing up fluid
starting at the top, insert lip of tub into slot in door boot. working both ways round, push door boot onto lip
fit outer clamp
push door boot on to lip of the cabinet and fit clamp.
test for leaks on a rinse cycle (water level is higher) water will be a bit foamy till washing up fluid is washed away
easy job but needs a bit of patience so go for it
Sep 07, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
385 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
