Question about Canon PIXMA iP3300 InkJet Photo Printer
Usb connection not known / printer not connected
Says printer is not connected, try connecting cable. changed usb port, took out cable and put it in again and then still didn't work. bought a new cable and still says the same. restarted computer too. would very much appreciate help
    Scholar:
  • 134 Answers
Solution: Uninstall / reinstall the printer driver (Windows) PIXMA Printers
Uninstall and Reinstall the Printer Driver (Windows) Follow the steps below to uninstall the printer driver:
  1. Select 'Programs' or 'All Programs' from the Start menu.
  2. Select the Canon printer driver you want to uninstall, and then select 'Uninstall' from the menu that appears.
    usb connection not known / printer not connected - ip4000_uninstall1.jpg
    Note: Click here if your printer does not appear in the Windows 2000, Windows XP or Windows Vista Programs menu.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the un-installation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and thenusb connection not known / printer not connected - ip4000_uninstall3.jpg />
    Note: If you use Add or Remove Programs to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in step 2.
In Windows Vista, Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
Note: You will not be able to complete these steps, if User Access Control is enabled in Windows Vista. Click here for steps to temporarily disable User Account Control, so that the printer driver can be removed.
  1. Make sure your printer is connected and turned OFF (or the power cord is unplugged).
  2. Turn on your computer and log on as Administrator.
  3. Open the Printers window.
    For Windows Vista
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    Right-click the Canon printer icon for your model printer and click Delete.
  4. Click 'Yes' to proceed with the deleting process.
  5. Click 'OK' to acknowledge you have deleted your default printer.
  6. Click 'File' from the Printers window then click 'Server Properties'.
    Note: For Windows Vista, click your right mouse button on any empty space within the window, and then select 'Server Properties' from the menu that appears.
  7. Click the 'Drivers' tab. Select your Canon printer from the list and click 'Remove'.
  8. Click 'Yes' to proceed with the deleting process.
    Important (Vista Users): If you turned off 'User Account Control', go back to User Accounts and turn it back on.
Follow the steps below to reinstall the printer driver:
  1. Turn off the printer.
  2. Connect the printer cable to the printer and the computer.
  3. Turn on the computer, and start Windows.
  4. Insert the Canon Software Setup and User's Guide CD-ROM into the CD-ROM drive. Setup Starts automatically.
    Note: If Setup does not start automatically, click 'Start' and then 'Run' from the taskbar. In the 'Open' box of Run window, type x:\msetup.exe (where x: is your CD-ROM drive letter). Then click 'OK'.
  5. When the Musb connection not known / printer not connected - ip4000_install1.jpgeen is displayed, click the 'Custom Install' button.
  6. ip1800_win_easy_inst2.usb connection not known / printer not connected - ip4000_install3.jpg><br /><br /></li>
<li class=When the License Agreement appears, click the 'Yes' button after reading the agreement, and then click 'Next'.
  7. File copying begins. After all files are copied, the Printer Port dusb connection not known / printer not connected - printer_connection_install.jpghe dialog box is displayed, turn on the printer.
    Note: If the port is not detected at this time, disconnect thusb connection not known / printer not connected - ip4000_install8.jpginter and reconnect it.
  8. Click 'OK' to end the printer driver installation.
Note: If you previously used a Canon printer that was connected with a USB cable, a message reporting that the USB driver will be updated may be displayed. Click the OK button to update the USB driver and restart Windows.
Temporarily disable User Account ControlNote: In Windows Vista, the 'Remove' button will not be accessible (grayed out) if 'User Account Control' is enabled.
-To disable 'User Account Control' temporarily, open User Accounts from usb connection not known / printer not connected - vista_uac_on.jpgr />
Click 'Turn User Account Control on or off'.
-Click the check box next to 'Use User Account Control (UAC)...' to remove the checkmark, and then click the 'OK' button at the bottom of the screen.
-Click 'Restart Now'
-Once the computer has restarted you will be able to remove the driver.
I hope it helps!!!
Posted on Dec 01, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
If i try to print, it says printer offline. it's turned on and plugged in, why can't i print from my computer? windows 7 if that helps with instructions
How are you connected to the printer? Is it a direct USB connection or a USB hub or print server?
If you are using a USB hub or print server, try a direct USB connection. (A cord of 6 feet in length or shorter is preferred.) Try a different USB port and a different cable. Make sure that both ends of the cable are well-seated. Next make sure that a known working USB device properly connects to the computer.
Next check if the USB ports are disabled due to errors, for security or power-savings. For the first check the device manager. Start > Control Panel > Hardware and Sound > Device Manager. Scroll down for the USB devices. If you see a red x or a yellow exclamation point in a triangle, try updating the drivers or enabling the USB devices. The third item is an advanced setting that you can access by right clicking on the desktop (anywhere there are no running programs or icons). Select Personalize > Screen Saver, next select change power settings. Then click the link to the Change the Plan settings. Then click the Change Advanced Power Settings link. Scroll down and check for when USB devices power down and adjust this setting.
If the above do not work, try uninstalling the printer, then remove the data cable. Reboot the computer and reinstall the printer from the CD or downloaded file from Canon. Connect the USB cable when prompted to do so.
I hope this helps.
(most often an offline USB printer is a cable/hub failure.)
Apr 19, 2011 | Canon PIXMA MP210 InkJet Printer
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Hp j3680 was installed but now it cant be recognised on the usb port.
Check your USB ports and cable. If you have the unit plugged into a hub, try directly connecting to the computer. (A bus-powered hub is at higher risk but failures are known with both.) Try swapping to a new port (if you are already directly connected to the computer). Check if a known working device works in the port. Ports can burn out under some situations.
Try a brand new cable as well. In some cases, you might want to try unplugging the power connection as well as the USB cable to clear any issues on the printer.
I hope this helps.
Feb 08, 2010 | HP J3680 Officejet All In One Printer
Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Feb 04, 2010 | Canon PIXMA iP3600 Photo Printer
My windows xp was reloaded and now when rehooking up my 7200 all in one, its not working. All wires are connected, original installation disk was used.
Did you install the printer software and drivers before you connected the printer to the computer by a USB cable? Uninstall any drivers that have already been installed then restart. You can get the drivers again from the web site, http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers . Wait until the software asks you to connect to the printer before connecting the USB cable. If you are connecting to a router for an ethernet connection, then that can be cabled together before installing the software.
If the drivers were installed correctly, start diagnosing a problem with the cables. Try new cables, changing ports, and a known working device on the port. When you reinstalled XP, did you include the motherboard drivers specific to your machine (that will have the USB and ethernet drivers)? If you missed those steps, you may need to uninstall the printer before doing that update and then restart.
I hope this helps.
Jan 29, 2010 | HP Office Equipment & Supplies
Can't scan--says usb not connected
Check your cable and ports. If you are running a laptop, make sure it is connected to AC. Plug in a known working device. If using a hub, directly connect the printer to the computer. Try a new USB cable. Check if your USB ports have been disabled for security or power-savings (in the Device manager or advanced power savings areas).
I hope these ideas help.
(sometimes a flaky USB port will see the device if you just unplug it and then plug it back in to the port. However, this will need to be repeated regularly.)
Jan 05, 2010 | HP Photosmart C4280 Aio Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Installing software
I had a similar problem.  Check you bios setup.  My bios turned off my USB ports when I first connected my Lexmark 83.  Crazy as it was, that was the fix.
Oct 25, 2007 | Lexmark X73 All-In-One InkJet Printer
Canon PIXMA  iP3300 InkJet Photo Printer Logo
111 people viewed this question
old marine
old marine
