TV Flickers! My TV Flickers, only seems to do it when programmes go into adverts,( not sure if that's anything to do with it) Its a Toshiba 15" LCD Flatscreen had it about 18months I've checked the cable connections, Help Please, it's driving me nuts'!!
  • 13,433 Answers
I would recommend that you use the ask me button of slinteriors, send him a request / select the free option and ask him about it, hes one of our best tv experts. I'm sure he could provide you with somekind of repair solution or other solution im not aware of.
go here
http://www.fixya.com/users/slinteriors
use the ask me button, post on forum - free. You can mention that I recommended you to contact him. He might not respond this minute but give him some time, I think hes worth the wait with over 25years in tvs!
Thanks,
Ekse
Posted on Sep 06, 2008
Why am I getting after retuning two vertical black lines either side of my screen on some programmes "?"
Try to check the connections between boards inside the tv. If you can then remove those connections and reinsert it. especially the connection which go to lcd panel from the mother board
check the videos to know hoe to remove the connections .
If you wish to get some details; check the site linked here
http://electro-medical.blogspot.com/
Plasma TV Repair Ribbon Cable Removal Install Tutorial Overview LG LCD TV Repair How to Replace 6871L 2045A Con Board How to Fix LCD TVs
Nov 04, 2015 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Cannot record externally from Humax bt you View box onto Toshiba RDXV60KB ( HDD & DVD modes). As I previously could? I am getting message E26 " Cannot record from this program". But the Tos
This error e26 gets thrown up on some digital rights management programs.this really just means you are not allowed to record...ever increasingly thanks to the big corps like sony drm carrier signals are put into some broadcasts to overcome copying infringements.there still is a way to do this with the right equipment.some tv channels get revenue from their advert counts so they put these signals in to ensure that you can only watch at broadcast or catchup on certain devices.what I can't figure out is I can record anything whilst it's being aired and still transfer to older equipment but not anything with latest ios and certainly not with sony recorders.
Jan 26, 2015 | Toshiba RDXV60KB DVD HDD VHS Recorder
My machine won't power on, as soon as it's plugged in the LCD flickers, could it need a new control board?
Sounds like the power supply to the board you mention is struggling, does it read anything intelligable?
Apr 23, 2014 | Krups XP2070 10 cup Coffee Maker/15 bar...
Volume will not stay the same on commercials or loud sounds like a gun shot tru volume is on
In the UK, there is talk of insisting the TV companies reduce the advert volume to the same level as programmes. There is a lift at present as it increases peoples awareness.
Mar 09, 2011 | Vizio GV42L 42 in. LCD Television
I just bought my tv last week, and it seems like the color scheme is out of whack. People's lips and ears are much more red or rosy than normal, and sometimes it looks like you can see the color going in...
H you haven't specified what type of tv it is but given it is last week you purchased, it can be assumed to be LCD/Plasma. A setup procedure I used to do on the old CRT tv 's when setting the customer controls were as follows.
1) set tv to locally transmittted programme material (eg News -NOT ADVERTS - They are always too bright
Sep 22, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Toshiba lcd tv flickers after being on 15 mins.
This is likely a power problem. Have the power brick checked by an electronics tech to see if it is cycling off and on over time. If the power supply is not the problem, you should consider returning it if you can.
Nov 19, 2017 | Toshiba 32HL66 32 in. LCD HDTV
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
