The DR-550 MkII is the upgraded version of the venerable,
original DR-550. ... Also, as in other drum machines in the
DR-series, you can chain patterns to forms songs - In the DR-550 MkII, up to 8
songs ...Boss DR-550 Mk II manual. Available ...www.synthmania.com/dr-550mkii.htm Just checked this site. I am sure this manual is the one you want
warc619, Maybe the "button" is only thing broken. Maybe the "switch" is broken. Yoyu will need to see if you can view some video clips of monitor disassembly and repair at YOUTUBE first. Then you will need to "teardown" your unit and determine exactly what component(s) have failed and if you can get new exact same size unit from "Digikey" or "Radio Shack" or "Mouser".... WOW! you may even need to learn how to carefully desolder the bad switch and solder in the new one. Good luck with the repair. You didn't tell us what type of monitor you own!! CRT or CCFL back-lit LCD???? 12fixlouie
Once installed, you will simply
run the program and select
the devices you would like to control from
menus. The software finds the right codes for you and loads them into
your remote control.
It is not possible to put this remote into learning mode until after you hook it up to the computer.
The ease of this remote is to be able to hook it to the computer to program it. Its simple and easy, all you need is your device model numbers and its good to go.
