Question about Epson EMP 500 Multimedia Projector
Epson emp 500 image projected upside down
I have been given a second hand epson emp 500 for use at church. However the sreen image from my laptop is projected upside down
3 Suggested Answers
  • 105 Answers
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
Posted on May 29, 2009
AJIN G
  • 6694 Answers
SOURCE: I hooked up my Think
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Posted on Apr 06, 2011
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
screen.
screen.
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
How do I flip the image on my Epson EMP 30 projector for ceiling mounting please?
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Feb 13, 2011 | Epson EMP 30 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
Image otherwayround. How to put the image right to project from th front
Hello. I'm assuming your model is the *ELP* 732...In any case, bring up the menu in the display, then choose the "extended menu" option. Next choose "Projection" from the choices. Then choose front or rear, right side up or upside down...
Sep 05, 2009 | Epson EMP-732 Multimedia Projector
Lcd projector projects images upside down???
May 29, 2009 | Epson PowerLite 62c Multimedia Projector
Image upside down
Check in the settings. One of them will have the option to invert the image not sure what it will be called. That should flip it upside right. I had the same issue with my projector when I first got it just messed with menu until i found it.
Feb 11, 2009 | Epson (V13H010L13) Projector Lamp for...
Screen image is distorted small using Epson EMP 821 with Latitude D620
Check Epson"s support site to see if there is a driver for the projector. Some projectors require a driver for the visual clarity, and lots of times the driver disc doesn't come with the projector, go figure, and don't ask me why.
Aug 04, 2008 | Dell Latitude D620 Notebook
Picture projected upside down
1-press menu button 2- press down arrow and go to setting and press enter3-go to screen and press enter.4-go to projection and press enter. select front and press enter.
Dec 15, 2007 | Epson EMP-74L Multimedia Projector
Epson EMP 500 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
