Sound in tv
Everything is discounnected, but the sound is still coming fromthe back of the tv. At first I thought is was feedback but that is not the case. I'm wondering if the tv is going bad after 4 years?
  • 13,433 Answers
Would definitely seem like a issue with the television.
I would recommend that you use the ask me button of slinteriors, send him a request / select the free option and ask him about it, hes one of our best tv experts. I'm sure he could provide you with somekind of repair solution or other solution im not aware of.
go here
http://www.fixya.com/users/slinteriors
use the ask me button, post on forum - free. You can mention that I recommended you to contact him. He might not respond this minute but give him some time, I think hes worth the wait with over 25years in tvs!
Let me know how it goes.
Thanks,
Ekse
Posted on Sep 06, 2008
Exhaust making noise sounds like its coming fromthe back but then it sounds like its coming frome middle
Exhaust sounds can be difficult to locate. The vehicle needs to be put up on a lift and a mechanic needs to look for where its coming from. A local shop will usually do this (look for the leak) for no charge, or a very small fee.
Sep 22, 2015 | 2006 Dodge Caravan
My AV-48WP74 JVC TV is making a pulsating sound and then shuts off. There is no picture or sound. How can I fix this problem and get my TV back working again?!
i'm having the same problem. I looked at the power board where the power directly comes in and there was nothing wrong with the power coming off it going to the main power board that goes to everything else on the tv. At first I thought it was a cap. but I'm not so sure it isn't something with the bulbs for the lenses.
Jun 10, 2010 | JVC AV-48WP74 48" Rear Projection...
My tv screen wont turn on,it makes a sound fromthe back that sounds like it's going to turn on but it dose not.And it blinks a red light were it says stand by more than two times.
2 time standby light blink is an error code that shows problem section in TV.
Model number and brand name of TV would help to understand that error code.
Dec 22, 2009 | Televison & Video
Was useing the oven and then everything stopped
Sounds like a house wiring problem or terminal block on the back of the unit. You seem to only have 110 volts to the unit. One of our connections may have burnt.(the clock thing I have seen many times, it is feedback.) Unplug the unit and check the wires from the unit and and to the house.
jim
Jul 27, 2009 | GE JD900WK / JD900CK / JD900BK Electric...
I have a vizio tv, sony dvd player and direct tv. i also have a denon avr-1905/785 surround sound receiver. i can't get the surrond sound to work while watching tv but it be comes through if i am watching...
If your TV has audio out and your surround sound has an audio in you need to get a lead to connect them together, most of them have - then you just select the Aux on the DVD/surround player (or whatever the input is called on the back) and everything comes through your speakers. If you only have headphone out jack on the TV it will mean you won't have your TV speakers working. I hope this is not really obvious to you and it was the first thing you tried!
May 05, 2009 | Audio Players & Recorders
Polaroid purple screen
I started to experience this problem as well. Eventually one day I turned my screen on and all the colors were crazy. Purple, Blue Yellow Green. I thought my TV was broken but then I noticed as well that the menu was not displaying the same issue. After messing with the menu for about 30 minutes I found the solution.
Go to SETTINGS. Then go down to DEFAULT. Select default and everything will be fixed.... for now. I think unplugging the TV over and over screwed up the settings. Hope this helps.
Oct 20, 2008 | Polaroid FLM-323B Television
Referral from Ekse. DLP Samsung spinning noise
the most likely cause would be either the color wheel or the cooling fan. If you listen at the rear cover can you dtermine where the noise is loudest? does the noise instantly go away when you turn the power off after its been on awhile? If so its the color wheel, If not its the cooling fan.
Sep 06, 2008 | Televison & Video
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
No sound on hitachi 53sdx01b
The first thing to try is rescanning the Freeview channels as it may just be a software corruption...if you have the option of "1st time installation" pick that.Also let me know if there is any buzzing sound coming from the tv..
Oct 16, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Audio interference
Is the sound comming from the speakers on the TV or the back of it? Plasma TV's can doing buzzing sounds when moved to higher elevations.
Jan 27, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
