Magnasonic tv/systemlink 3 rca remote
I have tried programming the remote but the light does not come on while holding the code search button, what is wrong?
SOURCE: SYSTEMLINK 3 RCA UNIVERSAL REMOTE CODE 4 A MAGNOVOX TV
Code Lists:
http://www.thompsontv.com/rcarc.html
Posted on Dec 27, 2007
  • 10 Answers
SOURCE: codes
For the RCU300WD visit http://www.thompsontv.com/rcarc.html
Posted on Jul 19, 2008
SOURCE: RCA systemlink 3 universal remote (RCU300) codes
I forget my code for my tv sharp I have my rca remote control universal
Posted on Sep 10, 2008
tengo un tv sharp y no tengo el codigo universal
Posted on Sep 15, 2008
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
I have an RCA system link4 remote but it won't operate my MAGNAVOX tv. have any advice?
http://www.ehow.com/how_5932125_program-rca-systemlink-remote-control.html?ref=Track2&utm_source=ask
http://www.google.co.in/#sclient=psy-ab&hl=en&source=hp&q=rca+systemlink+4+codes&pbx=1&oq=rca+system&aq=2&aqi=g4&aql=1&gs_sm=c&gs_upl=0l0l6l594l0l0l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=3cc78a7dcc01c3c&biw=1024&bih=527
so far i didn't try to solve this kind of problems practically as no customer approached me with this type of problems in my place (bangalore) ...... so sir i can't tell exact procedure ( short root ) ...... so i have given two links which may solve your problem ...... check first link & see whether you have followed same procedure ...... second link also may help you .............. but little time has to be spent .........
Oct 27, 2011 | Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
Do not know how to program the systemlink3 universal t,v. remote control to my t.v.
Option 1:
To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE***Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Option 2:
Thanks for the hints on your web site. For the RCA SystemLink 3 with the key pad, I could not get the sequences described to work. But they did point me in a direction which worked for my remote:
  • With the TV on (for TV)
  • Press and hold code search until the light stays on
  • Press TV (for TV) button once
  • Press the on/off button once
  • Thereafter, the light will stay lit and every couple to three seconds it will blink twice indicating it is trying another code.
  • When the TV turned off, I pressed enter. Thereafter the unit worked.
May 04, 2011 | RCA Televison & Video
Need code # for rca tv
If your remote control has a search button, this is how you do it-------- User submitted information for the SystemLink 3: To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
***IMPORTANT NOTE*** Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Nov 19, 2008 | RCA 3-Device Universal Remote with...
My RCA450 universal remote control does not have a code search button
the rca systemlink 4 remote is very good.it has code search and menue
try also the menue button on the tv itself
Nov 15, 2008 | RCA Universal Remote Control
Magnavox codes
Try holding down the the code search button until the LED lights.. Then push the TV button.. with the tv on Start pushing the power button at one second intervals until the tv turns off.. Then push the enter button. that should find the correct code.
Jul 18, 2008 | Philips Magnavox 27MS343S 27" TV
RCA systemlink 3 remote
My friend you gotta turn on manually your tv first.Then push and hold until the indicator light lights,then release the code search button now push and release the Tv button after that you gotta push and release the power button until the Tv turns off then you push the enter button to save the code.Good luck.
May 10, 2008 | RCA Universal Remote Control
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
