Question about SanDisk Sansa e250 MP3 Player
Cant find music folder
I have a RHAPSODY SANSA E250
when i put the mode on playforsure and hook it up to my computer nothing pops up and i cant find my device
but when i switch the mode to RHAPSODY my computer finds the device but i cant seem to find my music folder.
i have overfilled my SANSA E250 by 6mega bytes and it says i have to make room for that 6mega bytes and that is when my problem kicks in. because i cant find my music folder to make room. could anybody help me?
  • sdndinesh Sep 07, 2008
    i connect the USB of sansae250 MP3 player the Music folder can't display how to solve the problem
  • 43 Answers
When you enter the sansa folder, look at the adress bar at the top and at the end write music
like this : Computer\sansa\music the word sansa may vary
Posted on Sep 13, 2008
  • 8,596 Answers
Change USB mode to auto -IF it is avaialble in the settings menu - see manual for details.
Posted on Sep 08, 2008
I cant place song into my sansa e250
Did you use a media player such as Rhapsody?
You need to sync the music, not just dragging and dropping into the system's folder via My Computer.
Sep 28, 2010 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
I cant delete any songs
The e200 series players have 2 versions, plus a Rhapsody version.
How to check your version:
On the player
1. Go to the Main Menu
2. Select Settings
3. Select Info
4. Check the firmware version, if it says
v1 it is a version 1
( or Rhapsody
Rhapsody also supports Rhapsody service and channels
USB mode is Rhapsody/PlaysForSure instead of MSC/MTP for
the normal v1
Rhapsody fonts are smooth, antialiased )
v3 it is a version 2
Having a version 2 player, songs can be deleted on the player itself:
1. In playback mode, press submenu.
2. Select the Delete Song item.
For all versions you can delete songs:
1. Making a connection to a computer first.
2. Use the Windows explorer on the computer:
Select "My Computer" on the desktop and go to the internal memory or expansion card of the e250:
Go into the MUSIC folder. Select your songs inside the MUSIC folder and select delete.
Need more information ? Just post a comment.
Dec 31, 2009 | SanDisk Sansa e250 MP3 Player
I can't find my music folder
I would just update the firmware and start over from scratch.
The "Plays for Sure" system only recognizes protected WMA's. The other mode will not allow you to play music period. I've never heard of anyone having that problem with that particular player, but if what you are saying is true, then you will be forced to use only protected WMA files - which means you can never let your Rhapsody or other music service subscription expire. And if there is ever a problem, you will have to delete all and reload.
As an experiemnt load at least one Mp3 format file into the player, and see if it plays fine. If yes, then only use Mp3 files from here on out. They are less problematic.
Sep 06, 2008 | SanDisk Sansa e250 MP3 Player
Computer wont recognize the PlayForSure
Try getting windows media player 10 or 11
May 05, 2008 | SanDisk Sansa e260 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa c 240... how do i download media converter?
You don't need to Get the Sansa Media Converter to Transfer song on your player. the Sansa Media Converter is used to transfer photos and videos on the Sansa.and to transfer song on the Player this is what you need to know.
the Sansa has two modes wherein it may connect to the computer, the MSC (Mass Storage Class) mode and the MTP (Media Transfer Protocol) mode. If you are transferring un-licensed, non-protected songs, you may transfer them using the MSC mode by simply copying them on to the Sansa. This mode also allows you to use the player with Audible files. If you are transferring music that you have purchased or music that are licensed and/or proctected, you would need to use the MTP mode. To transfer these files, you would need to use Windows Media Player 10 or some other Music Softwares such as Rhapsody and Napster.
If you add songs to the player in one mode, then switch to the other mode, you will not be able to see the songs from the previous mode, though the space used on the player will still reflect their presence. If you cannot see your songs on your PC in one mode, please try viewing them in the other. In order to change the USB mode of the player, you must power the player on and go to "Settings." Under "Settings," there should be a "USB" option. It would then give you the choice to change it from "Auto Detect" (MTP which is also known as Playforsure in other Sansa) to "MSC (Also known as Rhapsody in other Sansa)."
To add songs using the MSC mode, follow these steps:
1. Organize your songs into folders and place it into one directory.
2. Open "My Computer" and open the "Sansa C240" drive for your Sansa.
3. If you see 3-4 Folder there, click on Tools choose File Opdtion, there will be a Pop-up screen and choose View Tab
4. Select on Show Hidden files and Folder Option, so you can see all the files
5. Choose MUSIC Folder, double click and Drag and drop all the songs on that folder, and It will go automatically on your player. OR highlight a songs, right click select COPY, go to MUSIC folder right click then PASTE and it will be save on your Player
If you still need the media converter...go to utorrent.com to download there software and go to this website...
http://search.utorrent.com/search.php?q=sansa%20media%20converter&e=http%3a%2f%2fwww.mininova.org%2fsearch%2f%3futorrent%26search%3d&u=1
Dec 13, 2007 | SanDisk Sansa c240 MP3 Player
No more music
- As with nearly ALL sansa e250 problems, formating it will bring it back to normal. 1. Connect it to your computer. 2. Open 'My Computer' and right-click the device. 3. choose 'format...' and then 'quick format'. 4. If you haven't done so, upgrade the firmware: -Find the firmware on the Sandisk home page. Don't use the wrong one, though. If you have a Rhapsody version, choose the e200r player. Download the .zip file and extract its contents (right-click, 'extract all'). Then connect your player to your computer and drag the extracted file to your player's drive. Now when you turn your player on, it'll undergo the firmware update. You can also update your firmware by connecting to Rhapsody with your player hooked up and following the firmware update instructions when the window comes up. If the firmware update window doesn't appear, then you have the latest firmware to date. 5. Test out the player and see if this method worked. If not, you may want to send it back sandisk or return to the retailer you bought it from.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
Re-formatted Sansa e260 - still 1.4 GB (out of 4GB) tied up
I'm going to try this suggestion from Sansa:
Thanks again for calling SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
There may still be music hidden in Rhapsody mode that you can't see.
To find this music go to the Tools menu in the upper left corner from any open folder in Windows XP.
Choose the last option, Folder Options
A dialog box will appear, choose the View tab and you will see a list of options.
Find and select the Show hidden files and folders option. Then click Apply, then OK in that order.
This will make any hidden files on your computer visible.
Now open My Computer and double click on the mp3 player to open it.
You should see a few grayed out folders. We will be looking for MUSIC and SYSTEM.
Open the Music folder to see if there are files there to delete.
Open the SYSTEM folder and look for a second Music folder deleting this folder will free A LOT of space..all of the pre-loaded music for Rhapsody channels.
Disconnect the device and check the free space.
May 29, 2007 | SanDisk Sansa e260 MP3 Player
Wont upload music onto device!
hey, the same thing just started happening to mine. Let me know if u find a solution.
Jan 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
81 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
