Question about Maytag Dishwashers
I have a Maytag dishwasher model DWU8860 and it doesn't always fill after a pumpout cycle
  • Maytag Master
  • 19,396 Answers
It is probably a faulty inlet valve. Check the float switch first.
See here how to locate the parts.
See also this advice for repairclininc:
" There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Sep 06, 2008
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Maytag Dishwasher - MDB6650AWW wont fill after initial fill
sounds like a bad module control. let me know if this helps with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Not filling or draining
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 21, 2010 | Bosch SHU43C05 Stainless Steel Built-in...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher will fill and drain, but will not cycle!
Bobalou If you just bought and installed, I'm assuming you dish washer is brand new. It means it has full warranty with Maytag. Do not do anything. It will void your warranty. Call Maytag authorized service. Gendos...post back
Jan 23, 2007 | Maytag 24 in. MDBH750AWS Stainless Steel...
Dishwashers Logo
234 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
