Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Poulan weedeater it won't start
  • number188fan Sep 29, 2008
    weed eater featherlite plus 25cc 2 cycle gas powered trimmer
  • rszaltis May 21, 2009
    no fuel to engine . Ireplaced the fuel line inside the tank. The carb will not prime . Other line ok.
    Problem Solver:
  • 15 Answers
So your weed eater fails to start. Is the unit fueled up? Since it's a two stoke the gasoline must be mixed with two stroke oil. The mix ratio is 40 to 1. That's 40 parts gasoline to 1 part oil. If there is fuel in the gas tank now, how old is it? If the unit was stored incorrectly the gasoline may have gone bad and gummed up the carburetor. If this is the case, the old gasoline will smell like varnish and the carburetor need to be overhauled and cleaned.
Posted on Nov 13, 2008
Hello i'am working on a poulan pro weedeater pp330 i need the adjustment on the air and gas mixture screws
it would be only on the fuel side--adjust all closed then open half way--this should allow to start then adjust to best idle
Sep 05, 2014 | Poulan Pro Weedeater Leaf Blower/vac...
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have poulan/weedeater leaf blower
ignition coil,or blown head gasket...
Nov 08, 2009 | Poulan Garden
My new blower just won
When did you purchase it? If it is under a certain number of days, you may be able to return it. Other wise you will have to find a warranty repair center for that blower and get them to look at it under warranty. Make sure you have a copy of your receipt when you take it in to the shop. ** But make sure the shop does not get a diagnostic fee or handling fee because they are getting paid by the warranty company.** You should not have to pay a dime if it is under warranty.
Good Day.
Oct 07, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
810 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
