Question about Magellan eXplorist 300 GPS Receiver
Explorist 300 problem
Loading of software (after satellites are tracked) won't stop. Screen freezes and have to remove batteries to turn unit off.
    Novelist:
    Scholar:
  • 86 Answers
Did the software come with your purchase? If so, you can clear the nand flash and re-load the software. If you have the software let me know and I'll tell you how to do it. -Daniel
Posted on Mar 15, 2007
    Scholar:
  • 48 Answers
Try to reseting to the factory defaults: Press menu - choose preferences - press enter choose reset default - press enter choose all - yes - press enter Good luck!
Posted on Jan 01, 2006
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
I have a Windows CE Sylvania netbook that won't boot to the desktop. I can turn it on, but it seems to freeze right as it turns on. It shows the start up screen where it says "Loading OS Image...
One temporary solution is to remove the battery for a while until all the capacitors in the unit discharge. Upon replacing the battery, you get one good power up try. Notice that the date and time have reset. Once you turn off the unit and try to power it up again, the problem comes back and you must again remove the battery for a while. There may be a patch to fix the boot loader, but I have not found it yet.
Jun 15, 2011 | Computers & Internet
Need new screen for magellon explorist 100 gps
http://cgi.ebay.com/Magellan-eXplorist-100-200-210-300-400-LCD-Screen-/350437050321?pt=LH_DefaultDomain_0&hash=item5197ad07d1
My recommendation would be simply to replace entire unit unless you have experience fixing electronics.
Mar 03, 2011 | Magellan eXplorist 100 GPS Receiver
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS! INITIATING MAP UPLOAD This message wont go away, and all buttons refuse to work. The only way I can turn it off...
Jeff, I had the same problem with my explorist 500. Your unit lost the "BASEMAP.MGI " file. You will need to get a copy of that file. Then install it.
Try this site http://imhz.com/2006/05/my-explorist-is-screwed.html
(I would recomend all explorist GPS owners copy and save that file and store it in a safe place. I have mine on a thumb drive).
Dec 05, 2009 | Magellan eXplorist 400 GPS Receiver
Loading Topo maps...210 says invalid base map??
To get the base map and to get your unit functioning again:
Install the firmware again:
Go to: http://www.magellangps.com/support/product.asp?prodid=1114
Or, if this doesn´t work, go to www.magellangps.com, click on"support", click on "legacy products" (left) and click on "eXplorist210 Europe" (do NOT click on "eXplorist 210 North America")
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions. You will have to register your GPS, register it under a European country.
After you have installed the firmware you will have the basemap and some new windows on the GPS. Good luck and enjoy!
May 07, 2008 | Magellan eXplorist 210 GPS Receiver
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
Button does not work
if you don't mind taking it apart, carefully unscrew the case and seperate the two halfs (be carefull not to break any of the wires or ribbon connections) , pull off the rubber pad with the buttons, and clean the contacts on the circuit board (you could use alcohol, or I use model railroad track cleaner that you can get at a hobby shop)
Jan 29, 2008 | Magellan eXplorist 300 GPS Receiver
Unit Freezes Up
Try turning off the WAAS function to see if that makes a difference.  If it's already off, try turning it on.  It's either a software/memory problem, or there's a short in the antenna. There is no update available for that unit.
Oct 26, 2007 | Magellan eXplorist 200 GPS Receiver
Explorist 300
since the unit doesn't have a base map it needs to be loaded with the base map so send it for a service so that the base map could be added.
Jan 04, 2007 | Magellan eXplorist 300 GPS Receiver
Magellan eXplorist 300 GPS Receiver Logo
286 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
