Question about Acer TravelMate C100 Notebook
Acer TravelMate C102 will not charge battery
The computer is working normally on mains, but will not charge the battery. The orange light is not on at any time. I have tried three different batteries, one of which is brand new. Any ideas?
Battery will not charge. Black box (on wire which connects to mains - sorry not good with techno!) light is on. Acer Travelmate 2480 laptop. Quite old I think, got it second hand. Does it just need a new...
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 04, 2010 | Acer TravelMate 2480 PC Notebook
The laptop has stopped working, it starts on the button but immediately shuts down. There is no power light shown from the mains when the battery is removed. When fitted the battery will not charge but the...
keithncp, Take battery to local shop to prove battery is good when a "dummy" resistive load is placed across terminals and measured voltage is within specification. If voltage falls off more than 1-2 volts, replace battery. 12fixlouie
Mar 12, 2010 | Acer TravelMate 2702WLMi Notebook
I have a acer travelmate 2428anwxci. When I plug in
Thsi problem arise when you have a bad BIOS version. Normally, you should update the BIOS with the latest version. go to www.acersupport.com and download a latest BIOS together with the flash tool. you should be able to charge the battery normally.
Feb 25, 2010 | Acer Computers & Internet
Battery flashes orange when Acer Aspire D250 is off & disconnectd
flashing light is normal..when batt is being charged.....
Dec 07, 2009 | Acer Computers & Internet
Travelmate only powers up with battery inserted. But AC still charges battery. Orange light goes on and of
Sorry to tell you this but you may have a problem with the charging system. That will require you to return it to Acer or an Acer service center. You can also try this. I got this from Acers' travelmate support website:
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
You can aslo google your specific model of Travelmate to see if others are having this issue.
Les
Jun 27, 2009 | Acer Computers & Internet
Acer Travelmate 2480-2968
You might have to try an new a/c adaptor.
Mar 09, 2009 | Acer TravelMate 2480-2968 Notebook
Battery works and then doesn't
first off all remove the batterey and just connect the laptop directly to the power adaptor and check out is it working properly with out battery as it should work without battery on power adaptoir.if it works that means the battery is faulty if it does not works that means the laptop main board is having loose connection problem get it repaired do not do it your self very risky.
Mar 02, 2009 | Acer TravelMate 2201LCi Notebook
Travelmate 2300 won't power on
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Oct 18, 2007 | Acer TravelMate 2300 Notebook
Acer 2303NLC
you need to charge the battery or connect it to a power source
Oct 04, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
