Question about Frigidaire FEF366 Electric Kitchen Range
F3 error light
The oven won't come on. It beeps and displays F3 on the digital display.
  • 943 Answers
Hi thanks for the question. the f 3 code says the oven sensor is open. that's the part located in the oven. top left in oven .cut the power to stove . replace the oven sensor thanks the appliance doc
Posted on Oct 06, 2008
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
I tried cleaning the oven and got the error F3.
Electronic control has detected a fault condition. Push CANCEL pad to clear the
display and stop the display from beeping. Reprogram the oven. If a fault reoccurs,
record the fault number.
Jul 13, 2009 | Electrolux Kitchen Ranges
Nothing Works Shows F3 Error
the F3 error code is an oven temperature sensor fault. The sensor is a small probe that sticks out of the back of the oven wall. They do go bad and can be easily replaced. If I had your EXACT model number (found along the inside of the oven door or lower drawer) you can replace it.hope this helps
Jan 26, 2009 | Kenmore 46123 Stainless Steel Electric...
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My oven displays F3 and beeps
f3 error code is generally a bad oven sensor. not every code is universal, but most manufacturers use the f3 error code to indicate a sensor issue. it is an easy fix if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Frigidaire FEF366 Electric Kitchen Range Logo
588 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
