Question about Scytek 2000RS-M Remote Control
Galaxy 2000 RS Remote Starter
When I press the start button, the 2 way remote control operates normally by beeping, but will not engage the starter motor of my vehicle. The remote starter battery is new. The unit was purchased, and professionally installed, and has worked well for the past two winters. This year it just won't engage the starter motor. Help please. Thank you yes the parking lights flash six time when i push the button on the 2-way remote
  • 2 more comments
  • mopspci Sep 06, 2008
    no the battery is fine
    i don't no what you main by trace the wiring that goes to the ignition harness
    When I press the start button, the 2 way remote control operates normally by beeping, but will not engage the starter motor of my vehicle. The remote starter battery is new. The unit was purchased, and professionally installed, and has worked well for the past two winters. This year it just won't engage the starter motor. the parking lights flash six time when i push the button on the 2-way remote in the car is ford escort 1993
    no the website did not help http://www.efunctional.com/scy2000rsm.ht... .
    President:
  • 1,263 Answers
There could be sevral reasons for this problem 1 there is either a loose positive wire or a loose ground for your ignition circuit from the remote starter module to the starter.(I would start at this first) 2 there is a relay that enegizes the circuit once you hit the button on the remote(This relay is in the junction box under the hood) 3 there is an internal problem with the module itself( Considering that the unit is 2 years old and is exposed to extreme heat and cold under the hood is a good possibilty) In a problem like this it is always wise to check loose or broken wires first. this includes the connection themselves. this is time consuming but nine times out of ten is often overlooked. now the unit itself is hard wired into your system which means there is always a fuse a fusable link or a relay. this is to protect the circuit as well as the componants. most often times people forget this basic fact. finally the unit itself even though you may think it's not possible, the life of electonics on vehicles isn't as good as you think, and considering you have no trouble starting the vehicle with the key tells you that it's not a problem with the ignition of the vehicle. these are the options to consider hope this answers your questions please rate thanks. if you need any more help just click on my name on the site
Posted on Sep 06, 2008
  • 1,879 Answers
Can you activate the starter motor manually (make it run without the remote) just to isolate where should we point our noses in.
    Genius:
  • 1,056 Answers
It sounds like the control unit has lost it's programming to the starter circuit. (in other words, the control for the unit is corrupt).
The control units have a lifetime warranty from the manufacturer.
So my first call would be to the place that installed it, and ask what their policy is for module control replacement.
If they won't cover it, contact the manufacturer, they should send you a replacement (you will probably need the information off of the unit for them)
  • Coss Sep 06, 2008
    One thing to be careful of. Since these units are under a lifetime warranty, opening the control unit, may void the warranty
    Master:
  • 638 Answers
Frequency problem due to moisture on the remote circuit ,just open the device clean the mini circuit located in the remote through a moist tissue and also blow hot air with the help of hair dryer on the circuit for a minite on that circuit ,it will work.as this same problem is faced by many of the clients due to moisture.
thanks.
please do rate the solution.
    Problem Solver:
  • 53 Answers
Hi ,
i've searched to find a solution of your problem , then i have found this website that may help you http://www.efunctional.com/scy2000rsm.html .
Good Luck ,
plzz rate my POST !
    Scholar:
  • 141 Answers
Sounds like the circuit that engages the starter system is not working. Are you able to trace the wiring that goes to the ignition harness?
  • Steve Froese
    Steve Froese Sep 06, 2008
    I will assume you can start the car using the key in the ignition, in which case the problem is definitely with the remote system. But you also stated that the vehicle lights flash when you push the button, which means the receiver is working. That only leaves the relay circuit which engages the car starter. It sounds like you are not equipped to troubleshoot the problem yourself, hopefully someone on this forum can help you, otherwise you may have to take it to a car audio/electronics shop.
  • 13,433 Answers
If everything else seems to be working fine I would suggest to double check the battery and the starter motor. not enought power to start up? Thats what comes to mind.
I'm not a professional car repair tech, you may ask other experts for advice
Thanks,
Ekse
2 Suggested Answers
  • 13 Answers
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Posted on Mar 30, 2008
Factory remote start wont work. hit button horn bbeps all lights and radio come on. when horn beeps second time car wont crank as it always has in the past
Ford Keyless Remote Car Starter fix - YouTube
? 5:14
https://www.youtube.com/watch?v=fQHb0mU0rvI
Jun 24, 2012 - Uploaded by mitch cox
I bought a 2010 Ford Raptor my remote starter won't work? when I press the .... 2013 lincoln navigator, 2-Way Remote StartSystem and i press button ... a Ford OEM 1-Way 100 Series Keyless Remote Start (CM5Z-19G364-A).
1998 to 2008 Lincoln Navigator Factory Transmitter Remote ...
? 3:00
https://www.youtube.com/watch?v=sLMN34KN3nY
Nov 2, 2012 - Uploaded by Lessco Electronics
1. Close all doors and then open drivers door and press the UNLOCK button on drivers door panel while door ...
2008 Lincoln Navigator Remote Start Accessories ' Th
Dec 12, 2015 | 2008 Lincoln Navigator
Electrical problem
Hi Anonymous and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2000 Aprilia Rs 125
Mar 25, 2014 | 2000 Aprilia RS 125
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
Dec 12, 2013 | Viper 5301 4202V Remote Start System and...
I bought a used truck with a bulldog remote starter in it but the guy has it set to start when it reaches a -10. I want to reset so only starts when I hit the button. The key fob looks alot like the rs...
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
Feb 01, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Remote starter on a 2004 Accord with V6 engine
remote starter is designed to shut down the vehicle if there is no key to drive with. This is a security feature so that unauthorzed drivers cannot steal it. to answer second question the purpose of remote starters is to allow you to heat up the vehicle so it is an ice cube when you are ready to drive. Not sure what remote I cannot answer the horn question. Need more on what remote starter you have model number and make
Apr 20, 2009 | 2004 Honda Accord
I cant start my car with the remote starter
You normally have to while the car is running transmition in neutral push the brake pedal, put the emergancy brake on, release the foot brake, press the remote start button on the remote, take keys out of ignition switch, car should stay running, get out, press the lock button on remote starter remote, car should shut off, and now is set
Feb 05, 2009 | 2002 Hyundai Accent
Galaxy 2000 Rs-m
yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
May 26, 2008 | Scytek 2000RS-M Remote Control
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Scytek 2000RS-M Remote Control Logo
221 people viewed this question
Top Scytek Televison & Video Experts
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
