Question about Frigidaire FRS23F4C Side by Side Refrigerator
Refrigerator side freezes
Only the top shelf and the ice maker filter is freezing in my refrigerator side.
Everything else seems ok.
    Novelist:
    Champion:
  • 220 Answers
Sorry to be late with the reply, but Frigidare side by sides have a flapper valve between the freezer and refrigerator that breaks and the cold air enters the refrigerator unchecked. Remove the shroud in the upper part of the refrigerator and you should see it. Usually the flapper is broken off and layind down next to the duct.
Posted on Dec 31, 2008
I have a Frigidaire Side by Side refrigerator model number ffhs2611lwb. The ice maker has not been making ice on a regular basis.
Turn the fridge freezer off' for a few moments then turn back on...it will do a self test and the damper motor in the fridge section rotates and operates a hit and miss type vent...they can break inside as it's only plastic.If the air flowing through the vent does not stop at all then you have a broken unit..I have repaired these! using a soldering Iron. Or purchase a new one.
Oct 07, 2015 | Frigidaire Refrigerators
Dan, I have a Frigidaire Side by Side refrigerator model number ffhs2611lwb. The ice maker has not been making ice on a regular basis.
This sounds like you are responding to someone in your original post?
Please post as a comment in that original posting as 'Dan' is unlikely to see it. Fixya gets 1000s of questions a day!
Andrew
Moderator.
How do I reset fridge model #106.51132210 it drips water from top and freezes on top shelf of fridge side
I'm not sure if resetting will help, but the easiest way is to just flip the breaker off and then back on.
Dec 04, 2014 | Refrigerators
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side refrigerator
hi there,
the freeze-up is caused by either a kink in the water line or a blocked air vent. check for both.
Nov 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Top shelf on refrigerator side freezes everything into ice
well..that's most likely due to a problem with the relationship between the control and the compressor.
is your unit under warranty?
Jun 03, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerator side freezing
kjn, I think what happened here is that the automatic damper assy. is stuck in the open position. This is why everything froze in the refer area. This includes the water filter and cartridge. I would unscrew the filter cover and see if it's frozen in there. If you find the filter frozen, take a hair dryer and go over it lightly until it will unscrew. After that you will have to check to see if the damper is stuck. You should be able to hear it open and close by turning the control on and off. Or get a mirror and hold it at an angle in back to see the gates. Part number for the damper motor is 240440701. Not that hard of a job...Catriver.
Jun 14, 2007 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS23F4C Side by Side Refrigerator Logo
96 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
