Question about Whirlpool Duet GHW9150P Front Load Washer
Door wont latch shut
My door wont latch closed
  • turn Sep 07, 2008
    Is there a pin on the top or bottom of the square part that the door catch goes into?
  • Anonymous Mar 12, 2014
    EWFLW65HIW0
    - the dispensor door latch seems to be broken - the door won't stay shut
    Novelist:
    Champion:
  • 261 Answers
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Posted on Sep 07, 2008
  • John Robbins
    John Robbins Sep 12, 2008
    On the grid above is your door latch, the pin is actually two hooks, like a car door latch, this part above is around 50 dollars and takes 30 minutes to replace. If the strike on the door lines up with the hole on the machine where the jaws are but will not shut then the jaws of the latch are worn out and need replacing.
    Five squares from the right is the latch and three squares from the left is the sensor switch telling the machine the door is shut. Either of these will produce the same result if open or not making contact by being depressed from the door closing.
Door wont latch
FIX CAR DOOR LATCH - YouTube
? 1:29
https://www.youtube.com/watch?v=wmWsM-TSaKo
Oct 21, 2011 - Uploaded by benherrerajr
Ever had a car door that wouldn't close? If the latch was accidentally stuck down, then here's the most ...
DIY Fix & Repair For Car Doors That Will Not Close
finley.xyz/diy-fix-repair-for-car-doors-that-will-not-close/
You are out and about and your car door suddenly won't close and stay shut. ... should be your first go to choice for repairing a car, truck or vehicle door latch of ...
Car Door Won't Close or Stay Shut - JamesMaurer.com
Jan 16, 2016 | Cars & Trucks
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
Drivers side door wont stay shut in my 97 jetta
lube the latch up...
go to the passengers side and examine the latch... you could use a screwdriver and OPEN the latch on the drivers' door by pulling the door handle and prying the latch to the open possition... and try to close it ... repeate.
Mar 27, 2013 | 1997 Volkswagen Jetta
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Front door latch jams and door wont shut
It sounds like the jaws are close. you need to pull on the door latch lever and hold it open use something round like a punch. not your finger. and open the jaws. if the door latch is not bad your door should close and latch normal.
Feb 25, 2010 | 2004 Chevrolet Aveo
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Door wont shut
When the door was last Opened the latch must have caught on something and went to the Closed Position. Get a Pair of Pliers and on the Door Where the Latch is Pull it Back Down or Up whichever way that it goes. All makes are Different with This.
Jan 01, 2009 | 1994 Volkswagen Passat
99 ford explorer door wont shut
sounds like the door latch has triped while the door was open.the door is held closed when the latch grabs around the u shaped bracket you can see when door is open.make sure door is unlocked then with a screwdriver or even a pen stick it in the door latch and slide the latch over to reset it.
Nov 14, 2008 | 1998 Ford Explorer
Whirlpool Duet GHW9150P Front Load Washer Logo
471 people viewed this question
Dan Webster
Dan Webster
Sal De
