Question about RCA RT2500 System
Static kinda sound
Im having a promblem with my rca rt2500 when i turn up the tremble there is a hissing type sound comming from only the front left and right speakers and i can turn the tremble down and it lightens up a bit but its still there faintly and on the speaker indacator on the reciever it shows red light on the left and right speakers i dunno what to do anyone have any asnwers
    Champion:
  • 277 Answers
Hi sounds like a earthing problem in the reciver or problem in the speakers try rotaiting the speakers back to front front to back left to right ETC.. good luck
Posted on Feb 26, 2006
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
My rca rt2500 turns of after thirty minutes of playing
Sound that the power supply section has the fault. Seek tech support.
Jun 04, 2012 | RCA RT2500 System
I am connected to the TV from the sound system. Of my six speakers connected, I can only get sound from the SW, and the front L & R speakers. No sound is coming out of the Center or Rear L & R. ...
You don't say HOW the 'TV' audio is carried to the RT2500? TV's are usually the end of the chain, not a link in it. For multichannel audio you need a multichannel digital source. Is that the TV or would it be the cable/sat box? Try running a digital audio cable from one of those to the RCA.
Dec 27, 2010 | RCA RT2500 System
A few weeks ago i would not get any sound then after the unit would warm up i would get a static sound for a while then it would clear up and be fine. Now no sound when i turn it on but after it warms up i...
Check all you wire connections to speakers and in the back of the receiver.If one is lose especially behind the amp it will create static noise..Did you move it around recently?It might have pulled a wire.Another thing that could cause that is build up of dust on the circuit board..Blow the inside out with a can of compressed air threw the holes in the side..Also check to make sure that in the wall outlet that you have it plugged into that its the only one there because that will also pick up static noise from the other accessories that you have plugged into it.Hope this helps you and have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Dec 07, 2009 | RCA RT2500 System
RCA RT2500 will not turn on
press and hold power button while unplugging and plugging power supply cord may take a few tries worked for me
Aug 16, 2009 | RCA RT2500 System
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
RE: RCA RT2500 Receiver
take the cable of right speaker(which is ok)and put it instead of the left cable if it is ok-your problem will be in your left speaker or its cable-if it is not working the problem in your receiver output stage.(left channel path problem)
May 18, 2008 | RCA RT2500 System
RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
Mar 14, 2008 | RCA RT2500 System
No Sound
Maybe the speakers are no good. Have you tried hooking up a different set of speakers?
Oct 11, 2007 | RCA RT2500 System
RCA RT2500 System Logo
173 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
