Question about Maytag Washing Machines
My maytag heavy duty fabric matic will wash and go thru the full cycle but it will not spin, i had a new belt put on it i notice a slight burning odor so i unpuged it russ
  • 141 Answers
This is probably the transmission.
Posted on Sep 06, 2008
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Maytag washer that fills, washes, rinses but does not spin. The dial moves around but when it comes to the spin cycle it clicks but nothing happens. It started with just the heavy-duty cycle. Now...
Make sure nothing is caught between the inner and outer tank.
Another possibility is the Lid Switch. Check the switch for continuity. If it is found to be open, replace the switch assembly. Here is a diagram of switch.
Check belt. If it's worn, replace it. Here is a diagram of worn/defective belts.
Sometimes the center bearing can get worn and bind on the transmission, this can, and will stop the washer from spinning and may also burn the belt. Try to turn the belt by hand, if it is super stiff it may be the center bearing has seized.
I hope this will be helpful to you.
Aug 11, 2009 | Maytag Washing Machines
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Open Questions:
Washing Machines Logo
375 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
