Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error 5100 What does this error 5100 mean? Our printer will not do anything now except flash. We recently changed the ink cartridges. What to do now??
    Problem Solver:
  • 10 Answers
Don't quote me on this but I think any error code over E 200 means servicing required.
Posted on Sep 06, 2008
How do you fix error message 5100 on my canon mx320 printer. I just went and bought new ink cartridges for it and put them in and now it doesn't work and this error message shows on my laptop
error 5100 means that the printer cartridge carrier can not move freely.
see inside the printer and find the one causing the cartridge carrier to stop. It could be a piece of paper or a dried ink on top of the absorber pads.
Apr 18, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
The printer keeps flashing e then 2 and when i try to print it says it is error 5100
I have an MP130. I find that when I have a 5100 error you just need to change the cartridges even though the software may say there is ink left in the cartridge. I think there is a chip on the cartridge itself when sends a message that the printer doesn't understand.
First off though you can disconnect the printer from the outlet, count to 10 and then switch it back on. Also, don't be tempted top refill cartridges or use anything but genuine replacements unless you want problems! Been there, done that :>)
Oct 11, 2010 | Canon PIXMA MP190 All-In-One InkJet...
The printer shows error code 5100 I think it has
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Good Luck.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Check Black Ink blinking...???
Remove the ink cartridges
Remove the printhead
Close the access door w/o anything in the printer
wait for a few minutes
Install the printhead only
install the color ink cartridge
install the black ink cartridge
if the error still there ( Repeat the cycle 5x)
or go to www.kodak.com/go/itg
Mar 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Paper feed pulling to the right during paper feed
Dear all,
Error code 5100 indicates CR (carriage return) error occurs. There are 2 possibilities of this case: Film timing **** strip is dirty or carriage part is faulty. Look inside your printer. There is a film, installed in horizontal position. Try to clean this film first;wipe carefully with moistened clothe. If the problem still persist, it seems that carriage is faulty.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon MP170
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR. en espera me sean indicados los problemas que se puedan subsanar un saludfo
Feb 28, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
172 people viewed this question
old marine
old marine
