Turn TV on. you can hear something in the tv making a spinning sound-- kind of like when you put a dvd into a dvd player. Picture is fine, just the sound.
  • mikecindyo Sep 06, 2008
    There doesn't appear to be an issue with noise feedback. The spinning sound is coming from inside the tv. My concern is that the tv is going bad after 4 years.
  • 6,487 Answers
Can you please provide us the model number and brand of this television so we can help you better with your problem...
Posted on Sep 06, 2008
    Brigadier General:
  • 3,614 Answers
Check all the wire audio/video connections on your tv...
  • 10,594 Answers
Please mention model number and brand of your tv to sort out sound problem.
  • 13,433 Answers
Double check your connections and cables, try another device in the same tv inputs to see if the problem is the tv or the dvd player, if another device works fine on the same input the problem would seem to be in the dvd player.
  • 19,396 Answers
The sond you hear is the safety switch that keep turning tv off because a fault is detected.
  • 1 more comment
  • Ginko
    Ginko Sep 06, 2008
    Whenever the TV control chip detects a fault, like a short, an overvoltage or a faulty component, a safety switch will prevent the TV from turning on.
    In this situation you get the TV in standby, not turning on, led on sometimes flashig, and a typical clicking noise (the switch).
    Try first unplugging power cable for one hour or little more. This will drain power from TV circuits, resetting sensors and settings.
    If this does not work , the TV need to be taken apart, and a technician must test the parts inside to find the fault.
    You can get repair service using the phone number listed in the user manual.
  • Ginko
    Ginko Sep 06, 2008
    If picture is fine the noise can also be crackling noise due to a faulty speaker, or a contact in the audio wires.
  • Ginko
    Ginko Sep 06, 2008
    The spinning noise can be the safety switch trying to engage, but in this case usually the TV does not last more than few hours , then it goes off.
    More likely it is a noise from the power supply, that is the only other part that can make clicking noise, since your TV does not have fan.
    Try wacking gently the TV on the sides and see if this affects the noise.
Samsung tv blank screen
It,s shot, Get a new tv,End make shure not to get a samsung,
Nov 03, 2012 | Samsung Televison & Video
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
Disney C1320PTVD TV/DVD Combi. Won't play discs just makes a spinning sound!?
You have to replace the DVD player. The problem is that parts are not available and it's difficult to open the unit. There are about 20 screws to remove, including four screws hidden behind each fender. You have to pry the fenders and rip them off to break two brackets that hold each fender on. The fenders still hold on fine with the remaining seven tabs on each fender. You have to eject the disc to get the mouth off.
I have a working DVD player for sale. It's from a car TV with a defective picture circuit, but the player runs and I hear the movie soundtrack, so I'm 99% sure it's good. I broke the mouth off the player, but it could be glued back.
If you have a good motherboard for sale with a bad DVD player, I might buy the motherboard from you.
Chris
email me: chris_goulet [at] yahoo [dot] ca
Oct 13, 2008 | Disney DTD1363-CAR 13" TV/DVD
Referral from Ekse. DLP Samsung spinning noise
the most likely cause would be either the color wheel or the cooling fan. If you listen at the rear cover can you dtermine where the noise is loudest? does the noise instantly go away when you turn the power off after its been on awhile? If so its the color wheel, If not its the cooling fan.
Sep 06, 2008 | Televison & Video
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
DVD PLAYER PLAYS BLACK AND WHITE
sir/maam it is possible that the DVD player is not compatible with colored tv,s or one more thing is kindly first adjust the screen focus of your tv,,,,thnksss and hope to help you!!!more power
Nov 25, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
