Question about Whirlpool Duet GHW9150P Front Load Washer
Door latch My door wont latch shut.
  • 5,911 Answers
The door latch is electro-mechanical. Which means, it has a mechanical mechanism that is electronically controlled. If the latch is broken, it is recommended that you replace it. The following link explains how:
If you require a replacement latch, they can be ordered on line at Just type in your model number and locate item number 7 under the "Door and Latch Parts" heading. The part number is 8181700.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 13, 2008
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut -
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
2006 Lincoln zephyr driver side door wont latch shut
try pulling the door handle a time or two, perhaps the latching mechanism is stuck in the latched position. sometimes pulling the handle and moving the latch with a screwdriver is needed. if this doesn't work then try lifting up on the door while shutting it, if this works then you need new door hinge bushings or new door hinges
May 28, 2010 | 2006 Lincoln Zephyr
Push door and it justs wont click shut moved swinging arm in door with screwdriver but wont lock
if it wont lock that means that its broken replace the whole latch. its easy just take the door panel off then take the linkages off the latch take out the two or three screws holding the latch on and pull it out. than reverce those steps when installing the new latch.
Jan 04, 2010 | 2006 Ford Focus
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Door wont shut
When the door was last Opened the latch must have caught on something and went to the Closed Position. Get a Pair of Pliers and on the Door Where the Latch is Pull it Back Down or Up whichever way that it goes. All makes are Different with This.
Jan 01, 2009 | 1994 Volkswagen Passat
99 ford explorer door wont shut
sounds like the door latch has triped while the door was open.the door is held closed when the latch grabs around the u shaped bracket you can see when door is open.make sure door is unlocked then with a screwdriver or even a pen stick it in the door latch and slide the latch over to reset it.
Nov 14, 2008 | 1998 Ford Explorer
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
