Question about HP PSC 1350v All-In-One InkJet Printer
HP psc 1315v (printer, scanner, copier) Will not print
I cannot get my printer to print. Light flashes next to "check printer cartridge". Nothing, however, seems to be wrong with the printer cartridge. Large letter E is also displayed. Whenever I turn the printer on, it always prints out a test page. Very occasionally, after a long wait, it may suddenly print out something that I had tried to print quite some time before. Would you be able to help me with this?
  • Anonymous Jan 08, 2009
    Same thing here.
The test page printing out every time it gets turned on is the printer's way of telling you it wants to be calibrated. Lay the test page on the scanner (follow the pictures on the test page) and scan it in. This should fix that problem and the "occasionally after waiting, something prints" problem.
Unfortunately, I don't have an answer to the "E" on the display or check printer cartridge light. Hope this helps!
Posted on Jan 23, 2009
Hp 1315v all-in-one printer will not recognize cartridge. Does anyone know how to bypass the coding that tells it to not recognize the cartridge?
This page addresses what to do if you get different blinking lights on the printer. Match up the blinking light on this page with the light on your computer. Then click the plus sign to expand the page and view the solutions. The solutions for blinking cartridge light are not easily pasted here and I can't bookmark to that solution.
Blinking Lights
One thing to keep in mind with ink cartridge problems is that the cartridge has a warranty as well. You might consider checking back with HP using the warranty on your cartridge.
Sep 29, 2014 | HP PSC 1315 All-In-One InkJet Printer
My HP 1315v psc is only printing the first half of the sentences. the last half is missing. It prints pictures ok, but not my letter I wrote. It's like I tore the letter in half and had only the left...
Mostly pictures are in color, if your color cartridge is good it will gives you good print,if your mono cartridge clogged you wont get proper mono prints.. remove mono cartridge take ear buds dip in to the water clean nozzles gently, take print out then chem repeat two three times if result not satisfied, replace mono cartridge..best of luck..
Sep 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
PSC 1315v won't print
When you go to scan and the power light flashes, that tells you your computer IS communicating with the printer, however it may not be a good connection. Below i described that more. If the connection is indeed fine, and you tried a second pc or re-installed software completely, then I would have to say the printer is dead to you. (ie. a chip on a logic board has failed). Please continue below.
Software may be at fault. Can you print a demo page on the printer? Generally it can be done without a computer connected even, just hold any large buttons on the front of the printer for a few seconds, lights should start flashing, and a test print should print. I bet it will, because you said it "copies without a gripe."
IF that works, maybe you can completely un-install the printer software from Add/Remove Programs, or you can install it on a second computer?
IF that does not make a difference, try a new USB cable if you can. OR See if the USB port on the back of the printer appears loose. Are you able to hold it upwards or downwards or move it around at an angle? You could print another page, and quickly hold the cable in, and pushed up at an angle, or pushed IN-AND-DOWN at an angle.
IF that can be confirmed, you would need a $1 store soldering iron and would have to take the printer apart, and heat-up the connections between the USB port and the logic board. Possibly need $3 of solder from radio shack or what not. Hope I
Sep 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
Check print cartridge flashing
cartridge circuitry damaged, replace with new one
May 26, 2009 | HP PSC 1401 All-In-One Printer
1315v printer , Printed one pic. now says check print cartridge.
clean the tab circuit of the carrier or the cartridge holder..
and then run a maintenance page..using the printer panel..
go to maintenance section ..and select clean printhead..or maintenance page..
and then print an alignment page..
to align the cartridge..
please let me know if it solve the problem..
Good luck...
May 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Error Message - PSC 1310 All-in-One
Sorry I posted the solution as a clarification request please allow me to re-post:
Here is what HP has to say about this issue:
This Link. Will take you to the site.
-Hope this helps.
May 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1410 will not print, printer icon is no longer on the bottom right hand corner of screen either. When i turn off the printer and turn it back on it prints the test page only.
Dear kappa, It is the problem related "Alignment of cartridge" your printer is working properly, I am suggesting a method, with the help of this method you will never get test page until you lift out your cartridge from your printer. When next time printer print a test page, take it and put it into the scanner, remember the printing area should be the side of mirror and the printer prints on the above side of the paper should be left side of the scanner. And press scan button, you will see the green light will be blink and a voice of scanner you will hear. After 30 seconds light will stop blinking, Next time when you will turn on your printer, it will not print test page.
Sep 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP PSC 1350v All-In-One InkJet Printer Logo
689 people viewed this question
Ben Johnson
