Question about Dishwashers
Water will not enter machine
Water will not enter dishwasher
  • thelongs411 Apr 30, 2009
    I can not get water to enter the machine. IT works but no water
  • Anonymous Mar 12, 2014
    Water not entering in the machine
    Scholar:
  • 141 Answers
If you advance the timer past the fill cycle (if possible) does the washer function?
If so, you either have a bad water solenoid or a kinked hose. If the washer does not work, then probably the timer is bad.
Posted on Sep 06, 2008
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
No water in the dishwasher
Jul 01, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Water not going into dishwasher
Water Inlet Valve
Float switch
Hope i helped you.
Thanks for using "Fixya".
Jul 01, 2009 | Maytag Dishwashers
No water
Water-inlet valve
Float switch
thanks and please do not forget to accept the solution
Apr 03, 2009 | Tappan MDB531RF Dishwasher
Water not coming into the dishwasher.
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck......
Mar 28, 2009 | GE Dishwashers
Dishwasher not filling all the way,
hi,
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck.........
Mar 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The machine is not taking any water in
First check the water supplies at the back of the machine.
That is either a problem wit the inlet valve , or with the water level switch.
See the following suggestions from Repairclinic:
Water-inlet valve
Float switch
Oct 10, 2008 | Zanussi Dishwashers
My Maytag dishwasher does not seem to getting water. After the cycle the soap is still in dispensor and dried up. I did not put in dispensor and placed them on the bottom and they were still there after...
When the dishwasher is nopt getting water into the machine, it means that either the floating sensor is stuck, or the water inlet valve is obstructed or defective.
" If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it."
From There's no water entering the machine
Sep 27, 2008 | Maytag Dishwashers
Ariston dishwasher
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Mar 01, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
