Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Handle removal we want to move it and it would be easiest to remove the handles
    Problem Solver:
  • 18 Answers
You would be better served to remove the doors, ready fridge to move,( empty, un-plug ) . Remove front grille, un-plug wiring to door dispenser, follow water line and un-couple at water valve, then two people remove phillips screws from top of unit have second open door and lift off bottom hinge. you can then remove lower hinge if necessary for clearance.It took me longer to type than this process takes. And to remove handles involves removing door liners, don't go there.
Posted on Sep 09, 2008
How to remove door handles only, not the whole
For inside door handles, a special tool is required. It slips behind the door handle or window crank and moves the clip down so the handle will come off. For the outside door handle, Take the inside handles off using the special tool (available at any auto parts store). Remove the inside door panel. Remove the retainer clips for the door/lock linkage.The outer handle is held on by bolts on the inside of the door. Good luck
Sep 26, 2014 | Cars & Trucks
How do I remove the handle in door panel? I'm trying to remove the door because my window fell off the track, it doesn't have power windows so I have to manually roll them up and down.
1- remove the window crank
2- remove any screws from the door panel; sometimes they are hidden by a plastic cap. look inside the elbow rest cavity; remove any screws you see.
3- insert a flat plastic or wooden tool in the shape of (roughly) a scraper, between the door panel and door and start prying the clips which hold the panel to the sheet metal. get as close to the clips as possible with the tool, as that will be the easiest way. there are about 8 of these clips on an average door. when all the clips have come loose of the sheet metal, lift the panel straight up to remove it. you will find a metal rod attached to the inside of your handle; unfasten it and remove the panel completely. that handle looks like it is part of the panel and cannot be removed separately.
Mar 15, 2013 | Cars & Trucks
Outer door handle does not open door on drivers side how do I fix it? Inner door handle works.
There are one of 2 things wrong here. Either the outside handle is broken, and you'll need another one, or it is out of adjustment and can be repaired. It's a little work to find out either way, the inside door panel must be removed. This is lots of screws, you'll see as you start removing them. The black triangle plastic near the rear view must be taken off, pry the little round plug out and then remove the nut. Finally the panel lifts up, give the bottom a smack upward with your hand, it WILL come up.
Now is the tricky part, you need to see whats wrong. There is a rod connecting the door handle to the door release. If the rod looks like it moves up and down when you move the outside door handle up and down then it needs adjusting.
See the picture of the door handle...the white nylon clip on the right must be separated from where it attaches to the rod, then the rod is positioned higher so the handle can pull it up enough to open the door.
If the rod does NOT move when you move the handle, either the rod is completely loose, or the handle is broken. Remove 2 nuts from the inside and the handle comes out, and put back in a junk yard or ebay replacement. Good luck...Chris
Sep 18, 2011 | 1991 Mercury Capri
How do i remove the fridgerator door handle
HOW TO REMOVE DOOR HANDLES (LFX25960
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
1. Removing Refrigerator Handle
Grasp the handle tightly with both hands and slide the handle up (this may require some force).
The keyhole slots on the back of the handle allow the handle to separate from the mounting screws.
CAUTION:The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION:When you assemble or disassemble handle, you must push or pull with reasonable force.
2. Removing Freezer Drawer Handle
Press the handle against door first.
Grasp the handle tightly with both hands and slide the handle to right (this may require some force).
If you need help:
http://us.lge.com/download/product/file/1000003873/LFX25960_LFX21960owners.pdf
Apr 29, 2011 | LG LFX25960ST Stainless Steel French Door...
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Hard to pull up handle
Are you asking about faucet handle or pop up drain . If you are referring to faucet handle the easiest thing to try first is to remove center cover from top of handle. It's the one with the moen insignia or name on it. These are usually just a friction fit so use a small blade screwdriver or knife blade to carefully remove cover. There is a screw that holds handle on cartridge. Remove screw and gently remove handle by pulling up. If you have not shut off water supply valves this will open valve and run water. Push down on carteidge stem to shut off water. Use a penetrating oil such as WD-40 and spray around cartridge.Allow a few mins. then pull cartridge stem up and push it back down several times spraying with penetrating fluid several times. You can move stem by gripping with pliers. This should help free cartridge . If this helps you can save on service call. Reinstall handle with screw and center cover. Hope this helps. Thanks
Nov 12, 2010 | Moen 1 Handle LavatoryWith Drain Assembly...
How do i change the latch inside the pass side door on a 1998 chevy truck
First you have to remove the trim ring around the interior door handle. remove the screws from the molded handle. pry the bottom of the door cover from the steel door at one corner and work around to the other side. lift up on door panel and it will come away from the door glass. then disconnect any wireing. Remove rivet at broken door handle and push assembly to the rear of the truck. detach the rods. replace with new handle and install in reverse order.
Mar 02, 2010 | 1999 Chevrolet Silverado 1500
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Jvm 1410 spacemaker xl1400
not the easiest thing in the world to do. From my notes, that requires actually removing that door. ughhh/
Apr 02, 2008 | Microwave Ovens
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
284 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
