Question about Mitsubishi WS-55809 55" Rear Projection Television
Blinking timer light
My timer light is blinking, I have reset and it continues to blink. It will not turn on. I have unplugged it, reset it and it won't turn on, just keeps blinking. Help.
  • SashiSuchit Sep 15, 2008
    I have 54" Mitsubishi HD TV-Medallion. All of a sudden the green light started flashing on the timer button. I have reset the button, turned off the TV and followed the instructions given in the menu book but it was no help. Please let me know what could be the problem.
Call a repairman
Posted on Sep 06, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
May 09, 2009 | Televison & Video
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Green Power light keeps blinking and set won't turn on
Blinking Problem
replace DM
Feb 06, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Power Failure, now the power/timer blinking light won't stop blinking
Four bad caps in DM module = common repair for qualified
Mits tech.................................T.
Nov 03, 2007 | Televison & Video
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
163 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
