Question about Broan-NuTone GSEH3K Air Purifier
Replacement of AE200 to GSEH3K
Will the GSEH3K replace my existing non-workng AE200 (676 NT 684 NT Nutone air exchanger from 1985)?
My house is 985 sq. ft. Will the new unit fit in my garage rafters where the old unit is?
Is there a dealer or Air service company in my Tacoma WA 98408 area to do the job?
Thanks for any help you can offer. I called Nutone and the service dealer they suggested had never done a replacement and could't offer any other dealers.
Found a dealer on line.
Posted on Sep 08, 2008
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
In house temp is high and furnace stll goes on
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
Apr 01, 2014 | Honeywell Digital Round Single Stage...
A/c fan works only in high
Hi, I suspect the a/c blower resister has gone,not sure of its position on your vehicle but usually under the passenger glove box. Hope this helps
Sep 22, 2012 | Standard 1985 85 Chevrolet Corvette Air...
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what...
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Apr 25, 2009 | Air Purifiers
Honeywell F 300 electronic air purifier
there's usually a troubleshooting guide stuck on the inside of the door.  it suggests a systematic flowchart for diagnosing the problem.
you should be able to isolate it to either the power supply (means replacement), or one of the cells.
on mine, one of the many little vanes got a bent during cleaning, and was shorting out.  (it doesn't take much.)  a quick visual and very little judiciously applied force straightened it out and fixed the problem.
i've also found that the unit will crackle a lot after a cleaning because of drops of water remaining in the cells, so i usually reassemble everything, but leave the unit turned off for an hour or two, which lets the blower on the furnace dry the cells for me.
May 29, 2008 | Air Purifiers
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Feb 02, 2008 | Ecoquest Flair Air Purifier
Copper contact points broken
There is a repair outfit located through the internet that seems reasonable for approaching for a more involved repair job. Contacting them may get you the parts you require.
The one I looked up had rebuilds available, so you might be able to get a replacement for a better price with your old one exchanged.
If you go this route, just do a web search for Ecoquest air purifier parts/repair
Jan 17, 2008 | Ecoquest Fresh Air Air Purifier
Replacement UV Lamp Source?
Dear Bill,
We have our custom dual frequency UVC lamps made here in AMERICA specifically for our SUN AIRE purifiers.
Our lamps are 9,000 hour lamps and should be replaced at about 18-24 months because it will lose its effectiveness to energize the air, thus no longer purifying your air.
The cost of our custom dual frequency UVC lamps is only $48 plus $5 SH. That equates to about $25 for your maintenance cost on our LIFETIME SUN AIRE PURIFIERS ~ MADE IN AMERICA!
www.betterair.com Please contact us at:
1-800-684-8253 and we'll get your new UVC lamp out to you within 24 hours.
We appreciate your business and look forward to serving you.
We'll be here ~ whenever you need us
Oct 10, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Freshaire by ecoquest air freshener
I would guess misplaced wire.
Depending on how many and which wires you displaced to accomplish the bulb replacement. I would have to guess that if you did everything correctly and perfectly then the circuit board failed.
My other guess is that if you removed the front panel to circuit board connectors, you may not have reconnected the smaller thin ones on the left in the correct position.
If those check correct and all the other wires are in the correct locations, then there is a repair outfit located through the internet that seems reasonable for approaching for a more involved repair job. The one I looked up had rebuilds available, so you might be able to get a replacement for a better price with your old one exchanged.
If you go this route, just do a web search for EQ air purifier parts/repair.
Aug 07, 2007 | Ecoquest Fresh Air Air Purifier
Broan-NuTone GSEH3K Air Purifier Logo
281 people viewed this question
Top Broan-NuTone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Broan-NuTone Air Purifier Expert? Answer questions, earn points and help others
