posted by Guest on Dec 30, 2005
Suddently, I've found that the X,C,V,M,Del,Esc keys can not work any more event that nothing happen. All of the other are normal.
I do not know how to do now.
Can I do not something for this problem?
Thanks a lot,
Best Solution
posted on Feb 26, 2006
hi
first: buy a cheap new 1, u can find in EBAY 20$ or even less
BUT U ASKED
its a iiky job
and the chances are not with you for success
but you asked
1. turn upside down the kebord through all the process
2. open all the screwes
3. slowly lift the upper lid clean all the dust and $@(&#* underneath
4. put everything in place
5. close the lid
6. open it and put the knobs u missed
7. close the lid with the screwes
8. see if you put all the knobs right
9. hope it will work at all
10. works? - good for you
dont work? I TOLD YOU!!!
GOOD LUCK
BUT U ASKED
its a iiky job
but you asked
5. close the lid
GOOD LUCK
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 10, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
This-may-not-be-a-hardware-problem. As-you-can-see-I-am-facing-currently-the-same-problem--again,2nd-time.SpaceKey,Enter,DEL-and-curser-up+down-do-not-work.(I-am-helping-myself-sometimes-with-the-OnScreenKeyboard,but-this-is-cumbersome.
Unfortunately-I-missed-to-write-a-detailed-doc-about-how-it-was-solved-last-time,3months-ago.But-I-remember-I-ran-an-ASUS-update-on-my-box.First,this-did-not-work-either/I-had-to-update-the-update-routine-first--funny.
After-running-the-live-update-the-hickup-had-disappeared.-But-now-it-is-back-again.And-that-update-is-running-for-hours+hours+hours.
br,Werner/Germany
br,Werner/Germany
Solution #4
posted on Jan 12, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Ive got the same problem with the same wirelss keyboard and wireless mouse. My g, h, v, m, esc, enter, del.
1. Press the button on the USB connecter.
2. Press the connect button sorta hidden on the back of the keyboard.
3. Make sure its on channel 1 (Use a pen to change if u need to)
4. Replace batteries n reboot
Worked for me. Except when I press m sometimes I get mh for no reason. (vice versa for h)
This Problem Also Relates To:
GE Wireless Optical Mouse
GE (97985) Mouse
GE HO98806 Keyboard
GE JascoŽ 98446 (030878984454) Keyboard and Mouse
GE JASHO97764 Keyboard
Memorex (3202-2362) Mouse
Acer (NSK8458AN) Keyboard
Can you Help with these Keyboards and Mice problems?
Toshiba (G83C0001K210) Keyboard
Replacing Keyboard in Laptop
How do I plug in the wire strip... Answer This...
Repair Service
Find Keyboard and Mice Repairman Near You:
