Brother MFC 8840D Check Original Error
I had an installer from ComCast in to install cable internet, and he drilled into the attic right over top of my printer. I attempted to get all of the dirt and mess off the printer with a dustbuster. But, now it says to Check the Original - Remove Original and then press Stop key. There is no original in the machine. I have turned off the power to it, unplugged it from the wall, opened the cover and pressed the sensor buttom, turned the printer off and pressed Menu while turning it on. Nothing works. I can print, but I can't get the Copy button to light up, so I can't copy. Is there a solution?
Thanks
JKW
  • cpajwilson Sep 06, 2008
    No, it is not still under warranty. It is 4 years old. How do I get into where the dirt might be to get it out?
    I went to the site goodhacker recommended and tried to Reset through Menu, but that did not work. I think that there is probably dirt that was sucked into the machine when I made a copy and that is what the problem is, but I don't know how to open up the machine to get to wherever the dirt is. Any solutions?
    Sergeant:
  • 241 Answers
HI if You can see my comment please Rate(FixYa) Experts Help
I would turn on the printer and open the compartment door that holds the ink cartridges let the printer reset the cart. to the center and then remove turn off the printer! before you (look for dirt or drywall ) and turn the printer upside down and gently shake it to remove any foreign objects.
Now put the ink back in turn on the power and close the lid.
The printer may ask you if this is new or used or original ink SAY USED and YES orginal this should help >
Posted on Sep 06, 2008
    Master:
  • 638 Answers
Its the problem of dirt ,but opening the device to clean the dirt is quite difficult as it is very delicate inside to handel it .calling a technician is very much advisable because he will do it properly and it will be safe .it will not cost u much as its the case of servicing the printer ,the cost will be not more then service charge.as if you do and some thing goes wrong the parts damaged are very costly more then a service charge for sure.
thanks.
please do rate the solution.
  • 10,594 Answers
As you said, printer was working fine before this issue, so simple solution is pick air-blower and blow air inside printer and make sure there is not dust left inside. then power up and try.
  • 19,396 Answers
That is probably caused from dust inside the machine.
Unplug the printer for 12 or 20 minutes.
Remove the toner and put it back.
See if this work.
    Master:
  • 763 Answers
Try to clean what dirt inside your device and then reinstall the driver to your computer. after that if still no works then send it to repair service. hope that helps!
CHARCOIS
  • 6,487 Answers
Try to reset the printer if you haven't done it this is the steps:
Press Menu,*,2,8,6,4 , It should say maintenance in the display after a short delay, press 01 then press 99.
Hope that helps...........
    Problem Solver:
  • 53 Answers
i've searched on the internet for this solution then i have found this website that may help you , http://www.fixyourownprinter.com/forums/laser/45427 .
plzz rate this POST !
    Brigadier General:
  • 3,614 Answers
Could be you have have damaged the cable inside the printer or there was some dirt stuck still inside...
let me kmnow
  • micromaster
    micromaster Sep 06, 2008
    did the printer still have a warranty...?
  • micromaster
    to avoid opening of unit... try to use a air pressure by blowing it inside the printer.
I want to hook up a printer/fax machine to my Wireless computer. HOW
check whether the wifi function of printer is on or not, there is utility of brother which searches the printer on pc after installation of the software , check it
Feb 01, 2013 | Brother Usb Cable/cord 4 Mfc-8840d...
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Does the briothers mfc 8840d scan directly to a pdf
well if you got a software disk from brother when you bought the printer if that has a scaning program o it install the disc on your computer and open it, put the paper on the scanner and view the advanced settings on the scan program if it has any otherwise search the settings and find the extension or format that it saves in and change it to what you prefer
Jul 04, 2010 | Brother MFC 8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Just got a new computer w/windows 7 and now my brother mfc-8840D won't scan to pdf now? Any ideas on a solution to fix?
How to get a MFC-8840/D/DN to scan to Windows 7 over the network or by USB:
First - Download the Windows Vista Full Driver & Software Package from Brother: Brother MFC-8840DN driver download page
Install the drivers using a custom install - pick only the Network scanning drivers, unless you want the other junk - no promises on how well the other stuff works.
Alternatively, if connecting the MFC-8840DN to Windows 7 by USB, download the Printer and Scanner Driver for Local Connection. It is a separate download. Install only the Scanner driver.
Once the Vista scanner driver is installed, you can test by running the built-in Windows 7 Scanner Wizard. Here are instructions on how to test.
As far as conversion to PDF, that will depend on the software. I am not sure if the Control Center or Paperport softwares work on Windows 7. I have not tried those. I have found that freeware STP will works fine.
Here is a link to the STP homepage.
Here is a link to how to use STP with the Brother MFC-8840DN
May 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
How to remove back corner panel at feeder cable in Brother MFC 8840D
If you mean the top left of the doc. feeder, you remove the cover by flexing slightly, remove a phillips screw, lift the scanner cover and there's a square hole on the lid with one of those flex clip retainers that you use a screwdriver to lift.
Jan 22, 2010 | Brother MFC 8840D All-In-One Laser Printer
Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Feb 25, 2009 | Brother MFC 8840D All-In-One Laser Printer
My brother mfc - 8840D will not scan, please help
if it can copy copy correctly then its not the scanner. most likely you do not have the scanner software installed.
Dec 23, 2008 | Brother MFC-8840D All-In-One Laser Printer
I am reinstalling my Brother MFC
What is the exact problem with reinstalling the Brother MPC?
Is it the printer driver or the cable connection?
To install the printer drivers, just insert the CD that came with the printer into your computer and follow the on screen instructions.
Nov 28, 2008 | Brother MFC-8840D All-In-One Laser Printer
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
358 people viewed this question
jasbo
jasbo
