Question about Asko W6021 Front Load Washer
My ASKO washing machine will not go through its regular cycle
I think I must have had a power surge this summer and my machine must have been on. Now, it will not follow its regular cycle but seems to stop without washing the clothes. I have turned the machine off for a long time (it is now over 2 months!) thinking it would reset itself, but it hasn't. I don't have a repairman near me for my ASKO so I am hoping you can help me and that this is a quick fix. Oh! By the way, I had to use the manual open lever for the door the three times I have tried to use the machine...
Thank you!
Fiona Stewart
    Sergeant:
  • 351 Answers
It may need the carbons in the motor replaced part no 8801195, is it pumping out the water if it doesnt the door wont release.
Posted on Oct 09, 2008
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
I recently purchased a Hitachi bread maker. We had a power surge and it stopped working. Is there a circuit breaker on this model?
Unlikely. This will need repair or replacement.
To avoid future issues , install a whole house surge protector on the main panel and use local surge protectors on expensive units.
Unplug the things not regularly used.
Aug 10, 2014 | Hitachi Kneading Paddle HBD103 Home Bakery...
I have a Whirlpool top loading washer. The motor does not come on on any of the wash cycles but it does come on during the rinse cycles. Does this sound like a timer problem? Could this have been caused...
sounds like it could be a fault caused by a power surge, it may be worth checking the carbon brushes in the motor if they are worn down the wont supply power to the armature especially under a heavey load such as washing or a fast spin a tell tale sign is clothes seem to be still really wet after a spin
May 30, 2011 | Whirlpool Washing Machines
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
Code 28
Error code F28 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Asko w 620-Cycles through the wash too fast-
This is your power supply chip it is called a partial resonance power supply chip with IGBT switch part number MR5060 by schne.
Aug 28, 2010 | Asko W620
My mr coffee Iced tea maker has been working great for a year. Tonight it tripped a ground fault breaker, and only started a tea cycle. I reset the breaker and the machine squirted once then started to...
we had one like this and we suspect a power surge damaged it. it worked fine one night, but we had a lightning storm that night and we think lightning hit out power pole and fried several of our appliances. the tea maker would come on but like you described it seems to forget what its doing. consider the possibility that a power surge got it (doesn't have to be lightning, several things can cause a surge)
Aug 12, 2010 | Mr. Coffee Iced Tea Maker TM1S
My washing machine is not draining and finishing the cycle
There should be a trap to catch small items that might slip past the seals of the drum. find it and clean it out. That might correct the problem.
However, you might be using too much or the wrong kind of laundry detergent. Front loaders can't use regular top loader detergent. Too much suds can cause the machine to stop. that may be why you find suds in the drum when you think the washing should be done.
Some units have lights that change as the washing process changes what it is doing. If it's working properly, the light indicating the door is unlocked will be lit at the end of the washing cycle. If the machine stops short of that, something is definitely wrong with the machine and requires a thorough inspection by a professional.
Jim Hart
Jun 20, 2010 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
491 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
