Wireless adapter i have HP laptop with built in wireless adaptor. i cant enable my wireless . when i switched it , the light remained amber. pls help . thank you
  • 2,071 Answers
Try to reset computer by unplugging for 1 hours and put it back after 1hour. If the reset did not work try using an usb powered hub in the middle, this sometimes fix the problem.
If the HDD still does not work after the above then it is probably faulty.
Here you can buy an USB hub: Linksys ProConnect USB2HUB4 4 Port Wired USB Hub
Posted on Sep 06, 2008
I have a laptop dv9210. my wireless card does not detect internet so i purchaesed another only this one does not detect either. how do i troubleshoot. light is amber on front of laptop. other laptops in...
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Click the '+' in front of Network Adapters.
Are both the "built-in" and the "add-on" wireless adapters listed?
Are there any "yellow" or "red" marks associated?
Double-click one of the adapters, and choose "enable".
Repeat for the other adapter.
Failing the above, find a "geeky" friend who can trouble-shoot,
or take your computer to any computer-store, for trouble-shooting.
Nov 27, 2009 | HP Pavilion dv9210us PC Notebook
I have reloaded XP on my 6 year old Dell Inspiron 500m and it appears to have forgotton it has a built in wireless adaptor. The wireless network icon only shows in the 'my connections' display when I...
For starters, make sure the wireless adapter is turned on. Some laptops have an external switch. Also, look to see adapter is enabled in the Device Manager (control panel > system). If you do not see an device manager, you may need to reinstall driver for the adapter. All drivers that came with system can be found online at Dell's support website.
Oct 12, 2009 | Computers & Internet
I had wireless for some reason it has been disabled how do i enable the wireless adaptor
To enable wireless adaptor, check for switch at sides of the laptop. There is a wireless switch which enables or disables wireless.
On some laptops, there is a function key (Fn), press Fn and F7(or F5) at the same time to enable it
Jul 27, 2009 | Acer (BCM94318MPG) Wireless Adapter
I cant enable my wireless adapter
First, check if the blue light or green light for your network adaptor is turned on. This color light means it is working properly. If it is red, or no lights, it is not working properly.
try checking if your wireless network adaptor's driver is corrupted.
go to "my computer", then right click to go to "properties", then go to the "hardware" tab, then "driver manager". There, look under network adaptor and check if that driver is functioning properly by right clicking it and then "properties".
If it IS corrupted, re-install it here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_6000&os=WW1&osl=en&catid=&impid=
Hope this helps! ^_^
Jun 22, 2009 | HP Pavilion dv4000 Notebook
Wireless network card
Hi there.
The wireless switch on the front bottom of the laptop, it's suppose to be blue when the button is on the right.
Right click on computer and select manage, go to device manager, and go to Network Adapters, try to see a network adapter called Broadcom, if it doesn't appear, it means that your computer doesn't recognize the wireless card and you may have to reinstall the drivers.
Please let me know how you get on.
Good luck
May 28, 2009 | HP Pavilion dv6000z Notebook
My HP wireless doesn't work? I don't have wireless connection on my compaq laptop anymore.
check your wireless adapter is on... the switch is on the front of your laptop and you should show a blue light when it's on, also go into device manager and see network adapters.. you should have 2 (the wire one built-in and your wireless network adapter.. if you only have one network adapter, check the front and see if the light indicating the status of your wireless network adapter is amber.. (if it's showing amber and you're sure it's in the on position you may have a motherboard problem and you may need to send the system back (I just had one of those with a compaq computer and since the item was within warranty the fixed in a week)
if your wireless adapter light is blue and you see your wireless adapter in device manager follow this instructions and you should be ok,
vista
http://www.home-network-help.com/vista-to-connect-wireless-network.html
xp
http://www.home-network-help.com/wireless-adapter.html
Oct 03, 2008 | Computers & Internet
Driver for built in network adaptor
Here is a link for the compaq evo d510sff. Pick the operating systen you are using then donload and install driver for you network adapter. This shouldl fix your problem.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=97130&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316517&taskId=135
Jan 11, 2008 | Computers & Internet
Wireless Adapter not working under Vista
when you say the radio button does not light up, are you refering to the light on the front of the notebook?, if so you can turn the wireless on and off by the little slider switch next to the light.
Sep 21, 2007 | Acer Aspire 5050-3242 Notebook
Open Questions:
Tech+Help{~1^877^778^89^69~}AVG Antivirus Support Helpline Number? USA 1-877-778-89-69 AVG Antivirus Support Helpline number is straightforward to use. AVG Antivirus Support phone number is open twenty four hours daily and seven days per week. AVG Antivirus support Helpline Number's agent will assist you with remote help.AVG Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are AVG Antivirus SupportUSA.Asingle call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number. AVG Antivirus Support Phone Number AVG Antivirus Customer Service Phone Number AVG Antivirus Tech Support Phone Number AVG Antivirus support Helpline Number AVG Customer support Telephone Number AVG Helpdesk number AVG Tech support Telephone number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number AVG Security Tech Support Number Free AVG Antivirus Customer Support Number AVG Customer Service Tollfree Number.
May 24, 2017 | AVG Computers & Internet
Computers & Internet Logo
124 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
