Question about Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 power up
When I power up my PC, the fan comes on but it will not load up the system. Do I have a power supply problem, motherboard problem, or something else? Usually the blue LED light on the switch comes on but not anymore. Any advice would be greatly appreciated.
  • cesarp Sep 16, 2008
    Helping a relative with the SAME PROBLEM. Had a tech verify the power supply is good but the mother board video is not getting to the monitor. Anyone out there with motherboard "try this" suggestions?
  • 395 Answers
Your problem sounds like its the power supply, a bad power supply will some times power the fans but the voltage isnt right to power the pc. you can get a tester for around $15 at a place like radio shack
Posted on Nov 27, 2008
When I turned my computer on most times the switch wouldn't start the computer I replaced the switch no power I'm thinking it's the power supply
CABEL8X1. NEED TO NO MOORE TO HELP.INFORMATION IS IMPORTENT.1 IS THERE FANS MOVING. 2 ANY LIGHTS ON THE MOTHERBOARD.
Apr 04, 2013 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 desktop pc powers up but NO VIDEO. I cleaned a massive amount of dust from the system and have checked every connection, cleared the cmos/bios, tried to power up with just the power supply...
Dust can be a massive cause of problems on a motherboard as it acts like a blanket causing components to overheat and sometimes conducts small amounts of electricity. Many boards on this condition are basically fried and need replacing. You could try a 24 pin power supply but i doubt that will make any difference as you have done everything to restore it.
Regards.
Apr 19, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
There is no power in motherboard
bad power supply or bad mobo are there any blown/bulged capacitors on the mothorboard?
Apr 09, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 boots then starts beeping and shuts off
First check your power supply section and check your power fan that is running properly. if ok then the suspected area is your processor section. please check it if its collar fan nor running properly then clean up or change that. and the other advice is please check your processor pin which are too tiny. be careful about these.
Apr 08, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway gt motherboard failure
Yeah that's right. Change/replace the power supply. Yet, you have to test the power supply's conditions if it still works alright. since you are suspecting both motherboard and HDD first. If yellow light comes and no action to the whole machine then that must be something in the motherboard. Before you finally follow your decision to change the power supply, check the motherboard. There are capacitors and examine if it didn't bloat. If it does, just take out the capacitors with exact microfarad and voltage specs or change the whole board. And granting though that the supply is bad, there must be some electric signals that have caused to the mother board which will eventually, at the end of the day, you encounter the same problem with it.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Hey man hows it going
Have you test the power supply for voltage, Is it good, if it is then the problem of course is not power supply. Some power supplies have a light on them. Also does the power supply fan work, If not almost always sure sign power supply is gone. Old power supplies are still available Every time I junk a computer P4 or older I save to power supply, What wattage?
Jul 10, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
My gateway GT4010
check the power plug first and see if it is properly plug in and turning on the power button, if does not work, get a new power plug and try as i've said again and if does not work the power system has problem and should be changed.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 Problem
This problem is video chip related. I have done alot of research on this and found that everyone has the same problem in some form or another. Your best bet is to junk the pc and get a different one, since the motherboard in the pc and the replacements you can get are all prone to the same failure. The best home remedy I have found is a hair dryer on the video chipset as mentioned in one of the above "fixes". Seems to work for a while, not permanent. You may need to repeat if your system goes down again. Also, when your system powers up and your screen looks more green than usual or different than it used to, just apply more heat and pressure. On another note, if anyone has a replacement for this case, GT4010, from a different manufacturer, please let me know. Hope this helps.
Oct 15, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Gateway GT4010 (RBGT4010) PC Desktop Logo
316 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
