Question about Panasonic CT-27G14 27" TV
Can only see a horrizontal line
I can only see a horrizontal line on the middle of the screen. Sound is fine, responds to remote. How can I fix this (what parts do I need to change), and where can I get schematics.
    Scholar:
  • 48 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Dec 30, 2005
JVC LT-32N310a No picture
even if you change the source ? or you cant do that ?
http://www.tvrepair.localdomain.me
Jan 07, 2014 | Televison & Video
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
My tv has a line across the middle of the screen. The sound is fine.
take it to a repair center for further help.what has happened is that the vertical out put has failed. so the set needs qualified electronic technician to solve the problem.
May 18, 2010 | Televison & Video
Harmony 550 quit responding as I watched a blu-ray movie.
Hi. The 'Welcome to Your Remote' messageon a H550 means that there is a button that is stuck down on the remote.
1. Take out the battery, and push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware. To do this, log in to the software, click 'Downloads' at the top and 'Firmware'
3. Update the remote.
That should get the remote working! :)
Apr 15, 2010 | Logitech Harmony 550 Remote Control
Help my lg L222ws-bn shows irritating horrizontal lines which desturbs the quality of the picture
seems to be a problem with the LCD Screen inside.can not be fixed and would need a replacement most probably.
try though,using it with another pc and see if the problem continues?
Feb 04, 2010 | LG Flatron L2320A 23" LCD Monitor
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Panasonic CT-27G14 27" TV Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
