Question about Jane Powertwin Azulon Stroller
Rear foot brake
The rear foot brake bar has plastic casings on either side which hold a metal pin which, when the brake is engaged, then slots into the grooves of the wheels. One of these plastic casings has split which has made the brake unreliable. I'd be grateful if anyone knows of a (UK based) solution.
  • 3 Answers
Seems to be a problem of this pram :( let me guess.. left side?! *g*
we just fixed it with cable strap (i can upload a photo if you need).
Posted on Sep 15, 2008
Remove foot brake lever
Hi Anonymous, remove brake rod clasp pin, rear master cylinder, rear brake line clamp to sproket cover, 3 screws that hold sproket cover, and foot rest mount. Good luck
Jul 12, 2013 | Harley Davidson XLH Sportster 883 Hugger...
How to fit a foot release pedal on a samsung su2931 vacuum cleaner
I have a Samsung SU2920. The pedal has broken. Spare is available on espares. To remove the broken pedal:
Turn the machine over and locate the foot pedal side near a rear wheel.
Operate the pedal to see how it is held in place by a moulded pin which is captured by two lugs on the underside of the body. Use a torch to get some light in there.
Insert a thin blade on either side to bend the plastic lugs slightly so that the moulded pin on the foot pedal can slide upwards without being held by the lugs. The pedal will not slide up easily. I used a hammer and a metal bar to tap it free.
Once the pedal is removed, the spare can be clicked into place from the top without tools.
Jan 04, 2012 | Samsung Vacuums
Have started to remove parts for new application of forward controls on a 2001 Harley Sportster 883. Have disconnected brake rod from brake lever pedal. Have been unable to remove clevis from the right...
If I'm thinking about the right thing, the clevis that is attached to the rear brake lever that the rod that goes to the rear brake master cylinder connects to, the clevis should have a pin connecting it to the rear brake lever. On the backside of the pin is either a cotter pin or a circlip holding the pin in. You may have to take the rear brake lever off to access the circlip or cotter pin.
Good Luck
Steve
Sep 20, 2011 | Harley Davidson XLH Sportster 883 Hugger...
I have a Baby Jogger City Select (manufactured 10/2010) and have an issue with the handbrake. When you pull the lever on the handle bar the cable, which runs to the rear axis, pulls out a little metal bar...
I did not have to disassemble at all. Thanks to your comments. I just took off the wheel with the stuck pin; gripped the pin with large pliers and a tight grip; pulled slightly outward while turning pin. Did this a couple times and the pin shot back into place!
May 07, 2011 | Baby Jogger 2010 City Select Baby Stroller...
I have an isuzu tfs 1999,i have a handbrake problem,i have adjusted the handbrake as far as it will go but it won,t hold.
For starters, set the cable adjustment back to the original setting. We in the States have something similiar called an Hombre. Follow the instructions for adjustings the rear brakes FIRST. Once these have been adjusted, if the brake will still not hold, then and only then, adjust the cable setting a couple of turns at a time until at least 3 - 5 clicks are achieved when setting the parking/emergency (depending on where you are in the world) brake. Let me know if you need anything further.
REAR DRUM BRAKES
See Figure 1
Normal adjustments of the rear drum brakes are automatic and are made during the reverse applications of the brakes. The following procedure should be used ONLY if the linings have been replaced.
Fig. Fig. 1: Drum brake adjustment
  1. Raise and support the rear of the vehicle safely using jackstands.
  2. Using a punch and a hammer on the rear of the backing plates, knock out the lanced metal areas near the starwheel assemblies on each plate. The metal areas may already have been removed and covered with rubber adjustment plugs, if so remove the plugs by grasping and pulling with a pair of pliers.
After knocking out the lanced metal areas from the backing plate, the wheels must be removed and all of the metal pieces discarded, then the wheels should be reinstalled for adjustment.
  1. Insert a suitable brake adjustment tool such as J-4735 or equivalent, into the breaking plate slots and engage the lowest possible tooth on the starwheel. Move the end of the brake tool downward to move the starwheel upward and expand the adjusting screw. Repeat this operation until the wheels can JUST be turned by hand. This is a position immediately before the brakes lock.
The brake drag should be equal at both wheels.
  1. Back off the adjusting screws 24 notches (clicks). By the time you have backed off the adjustment 12 clicks, the brakes should have no drag. If a heavy drag is still present, the parking brake cable is likely in need of adjustment.
  2. Make sure both sides of the brakes are properly adjusted. When backing off the brakes on the other side, the adjusting lever must be backed off the same number of turns to prevent side-to-side brake pull.
  3. After the brakes are adjusted, install a rubber hole cover into each of the backing plate slots. To complete the brake adjustment operation, make several stops while backing the vehicle to fully equalize the adjustment.
  4. Road test the vehicle.
Apr 29, 2011 | Isuzu Pickup Cars & Trucks
Trying to get right side foot peg case off foot peg seems to have a nut behind case not sure how to get off
Yes there is a nut on the backside of the stud that the peg mounts to. The stud is also the shaft for the rear brake pedal. To get to the nut, take the master cylinder loose and the snap ring that holds the rear brake pedal on or the remove the pin from the brake pedal. Now, take the large nut below the peg and brake pedal shaft off and the other two bolts that hold the front sprocket cover on. Remove the cover and you can get to the nut.
Good Luck
Steve
Apr 03, 2011 | 1993 Harley Davidson XLH Sportster 883
I have a 2004 toyota tundra and tried to engage the 4 wheel drive and it won't engage it just keeps blinking any ideas?
Its possible the 4wd actuator on the transfer case is sticking from lack of use. Its a black plastic part located on your transfer case on the drivers side rear with a electrical connector attached. Tap on it lightly while someone activates the 4wd button. Have truck running in neutral with foot on brake. (dont get run over). If it goes into 4wd, then just remember to cycle it into 4wd and back again once or twice a month to keep it from sticking.
If all this doesn't work a dealer will need to look at it.
Dec 19, 2008 | 2002 Toyota Tundra
Headliner removal
this is not an easy repair w/o damaging the headliner. There is nothing up there except maybe a roof brace. Check the luggae rack again by trying to move all the peices. One must be loose.
there are 27 steps!
If equipped, remove the overhead console.
  1. Remove the screw and disconnect the electrical connectors
  2. If equipped, remove the electronic compass sensor.
  3. If equipped, disconnect the auto dimming interior mirror connector.
  4. Remove the interior/map reading lamp. For additional information, refer to Section 417-02 .
    • Upon installation, make sure the notch in the headliner aligns with the tab on the interior/map reading lamp bracket.
  5. Disconnect the roof opening panel electrical connector and the wire connector pin-type retainer.
  6. Remove the gimp around the roof opening panel.
    1. Remove the sun visors. For additional information, refer to Sun Visor in this section.
    1. Position aside the door opening weatherstrips
  7. NOTE: Installing the LH side sun visor clip will support front of headliner while working on headliner.
    Install the LH side sun visor retainer clip.
    • Loosely install the screw.
  • Disconnect the electrical connector and the wiring pin-type retainers on the A-pillar.
    1. Release the upper B-pillar trim panel clips and position aside the upper B-pillar trim panel.
    Release the C-pillar trim panel clips and position aside the C-pillar trim panel
    1. Remove the rear upper headliner trim panel.
    2. Remove the D-pillar trim panel.
    Vehicles with rear climate control
    1. Remove the rear auxiliary A/C controls.
      • Disconnect the electrical connectors
    2. Position aside the LH rear quarter trim panel.
    3. Disconnect the electrical connectors.
    4. Remove the pin-type retainers and the upper air duct.
      • Push down on the air duct, tilt the top outward and pull upward to remove the air duct
    5. Remove the lower air duct.
    6. Disconnect the electrical connector located at the C-pillar.
      • Release the wiring harness pin-type retainers.
    7. : To prevent damage to the coat hanger retainer, use a 3/16-inch flat-blade screwdriver for this step. Remove the third row coat hooks.
      • Open the access cover.
      • Insert a screwdriver into the coat hook slot and turn the screwdriver 90 degrees so that it engages in the plastic component slot. This will spread the steal attachment clip wings to allow the plastic component to disengage. The steal clip will stay engaged in the sheet metal.
    8. Remove the rear headliner pin-type retainer.
    9. NOTE: An assistance is required to help support the center of the headliner for the remaining steps.
      1. s2n~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To prevent damage to the coat hanger retainer, use a 3/16-inch flat-blade screwdriver for this step.
        Remove the second row coat hooks.
      2. Remove the LH side sun visor retainer clip.
        • Open the access cover and remove the screw.
      3. NOTE: Rear seats must be folded down and front seats reclined back for this step.
        Tilt the RH side of the headliner upward and remove the headliner from the rear of the vehicle.
    good luck
    Dec 14, 2008 | 2002 Ford Explorer
    Parts fell out
    WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
    Apr 18, 2008 | Brother SE-270D Computerized Sewing...
    Jane Powertwin Azulon Stroller Logo
    319 people viewed this question
    Top Jane Baby Gear Experts
    Shehu Pro
    Shehu Pro
    Thomas Perkins
    Thomas Perkins
    john h
    Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
