Question about Adaptec Smart Cooling (ACC-9700) CPU Fan, Cooling Fan
Thermostat question... I've got the Adaptec Smart Cooling Fan. I've got the power cable connected to the motherboard. However, I don't know where to hook up the thermostat cable. I have an ASUS A8N5X motherboard. Thanks! -taulce1
    Champion:
  • 277 Answers
Hi place it far from the motherboard soo it wont start or opreate all the time (warm place) although there isnt any problem that it will work all the time soo it dosent really matter.... good luck
Posted on Mar 21, 2006
How do I remove and replace the water pump on a 2006 Chrysler 300 hemi 5.7 l.
5.7L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect negative battery cable.
  3. Drain the cooling system.
  4. Disconnect negative battery cable.
  5. Remove the upper radiator hose.
  6. Disconnect cooling fan electrical connector.
  7. Remove cooling fan mounting bolts.
  8. Remove the radiator cooling fan assembly from vehicle.
  9. Remove the radiator fan assembly.
  10. Remove accessory drive belt.
  11. Remove thermostat.
    NOTE The water pump mounting bolts are different lengths. Note the location of the water pump mounting bolts.
0996b43f80200d65-mw3da2o1okphbx00ygfzxzdl-4-0.jpg To install:
  1. Install water pump and mounting bolts. Tighten mounting bolts to 20 ft. lbs. (28 Nm).
  2. Make sure double ended bolt is in the proper location. Tighten double ended bolt to 20 ft. lbs. (28 Nm).
  3. Position the radiator cooling fan assembly in vehicle.
  4. Install cooling fan mounting bolts. Tighten to 50 inch lbs. (6 Nm)
  5. Connect the cooling fan electrical connector.
  6. Install the upper radiator hose.
  7. Install thermostat.
  8. Install the accessory drive belt.
  9. Install the radiator fan assembly.
  10. Connect negative battery cable.
  11. Fill the cooling system.
  12. Pressure test cooling system.
Mar 16, 2017 | 2006 Chrysler 300
Where can i get a replacement on board fan from?
fans are pretty standard things with only 2-3 different sizes so you wont have great difficulty getting one from your local friendly neighbourhood pc repair shop...or electronic retailer unless you live in the Australian Outback or Outer Mongolia or somewhere equally remote. Try a Tandy/ Radioshack/Maplins/PC World-you don't say what country you're in so can't 2nd guess what retailers are near you.
Don't forget, these things aren't motherboard specific; if it's your cpu chip fan then that's more specific to the cpu processor; try searching for that, and if it's just a motherboard cooling fan, then measure the length of one side in mm, and search for that size fan. The fan voltage is always 12volts.
Jun 11, 2012 | DFI LANParty UT RDX200 CF-DR Motherboard
How to replace the motherboard in a Compaq D510 computer
The Compaq D510 desktop computer uses a U-ATX size motherboard that is smaller than the standard ATX size. If the motherboard on your Compaq computer has stopped working or you want to upgrade to a different motherboard with different expansion slots you can open the case and replace the motherboard.
to replace the motherboard, just follow these steps:
  • Double click on the "Smart Cover" icon on the desktop. Enter in the Smart Cover lock code if you have set one up and click on "Unlock" to disengage the hardware lock that prevents the case panel from being opened.
  • 2
    Click on the "Start" button at the bottom toolbar of the desktop and choose "Shut Down." Unplug all of the cables from the back of the computer once it has finished powering down.
  • 3
    Set the Compaq computer case on its side and remove the two screws connected to the top and bottom ends of the case panel. Slide the panel to the left and pull it directly off the case.
  • 4
    Disconnect the SATA cables running from the power supply, drive bays and processor fan to the motherboard. Remove the screws holding any expansion cards you may have previously installed into the AGP ports on the lower right side of the motherboard and then pull the cards out.
  • 5
    Pull back the clamp holding the processor fan on. Pull the fan and then the processor off of the motherboard. Pull off the RAM modules from the motherboard.
  • 6
    Remove the screws holding the motherboard into place and pull the entire motherboard directly out of the case. Check the orientation of the replacement motherboard and make sure the USB ports and AGP expansion card slots are facing towards the back of the case. Lay the new motherboard down into the case onto the mounting screws sticking out of the bottom panel.
  • 7
    Place the processor back into its socket on the motherboard and connect the fan on top. Snap back on the fan clamp. Place the RAM modules back into their slots. Re-connect all of the SATA cables to the drive bays and power supply.
  • 8
    Set the side panel back onto the case and re-connect the case screws. Connect all of the cables into the back of the case and power the computer back on. Wait for the operating system to load to make sure the motherboard is working properly.
  • 9
    Navigate back to the Smart Cover program, enter in the password, and press the "Lock" button.
  • Dec 06, 2011 | Compaq Computers & Internet
    My acer aspire one notebook laptop when I push the power button comes on and shows the start up screen and then the screen instantly goes to this black screen with a little white line blinking in the top...
    Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile. Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping. There are several causes and solutions for this problem.
    1.Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
    2.Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
    Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
    3.Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    4.Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
    Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
    I hope you find it very helpful.
    Aug 25, 2011 | Acer Aspire One PC Notebook
    What do i need to take off in order to put the thermostate on a Ford Focus 2007?
    Hello! Here is procedure to replace the thermostat on your vehicle.....Guru.....Saailer
    1. Thermostat and housing are an assembly
    2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
    4. Raise vehicle.
    5. Remove or disconnect the following:
      Accessory drive belt shield Accessory drive belt Two power steering hose bracket retaining nuts and position the hose and brackets aside. Cooling fan motor and shroud 3 A/C compressor bolts and position the compressor aside Hoses from the thermostat housing
    6. Remove the bolts, the thermostat housing and the thermostat as an assembly.
    To install:
    NOTE Lubricate the thermostat housing O-ring with clean engine coolant.
    1. Install or connect the following:
      New thermostat/housing assembly and tighten the bolts to 89 inch lbs. (10 Nm) Hoses to the thermostat housing A/C compressor bracket and compressor and tighten the bolts to 18 ft. lbs. (25 Nm) Cooling fan motor and shroud Power steering hose, bracket and tighten the nuts to 89 inch lbs. (10 Nm)
    2. Fill and bleed the cooling system.
    3. Reconnect the negative battery cable.
    retailerIdd874f148debugOnfalsecustomerId117788472vehicleId3089401
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    Sep 11, 2010 | Ford Focus Cars & Trucks
    I don t know how to connect usb and rapidfire
    its pretty simple. There is a cable on the end of it theres a connector that has the pins like this
    http://www.majestron.com/pics/9-Pin%20Card%20Reader.JPG
    thats the USB header and that goes into your motherboard USB ports wihch are typicall yon the bottom.
    Jan 02, 2010 | Aerocool CoolPanel II Fan Controllers
    I.ve changed my motherboard and no longer have a 3 pin connection for the case fan on the motherboard. I know that + goes to yellow and - goes to black but where does the sensor wire go?
    Hi:
    An option for you is to just purchase a cheap adapter to plug your case fan into a unused power supply plug, such as one that plugs into a hard drive or optical drive.
    Dec 11, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
    Installed new stat and fan won't come on in heat made or cool mode.
    Turn the thermostat switch that says fan on------auto to on an see if the fan comes on ,if don,t then the problem was the circuit board or find power wires going to the fan motor and jump it out to see if the fan motor is good or bad. then if it starts, then you,ve know ,you,ve eleminated the fan motor and its the circuit board...
    Dec 08, 2009 | Intertherm P3RA-024K Air Conditioner
    Psu
    Hmmm.... mainly you have:
    -20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
    -4 or 8-pins connector that powers CPU
    -the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
    If you totaly unshure, there is manual:
    Illustrated How to Replace an ATX Power Supply
    Sep 05, 2009 | Computers & Internet
    Adaptec Smart Cooling (ACC-9700) CPU Fan, Cooling Fan Logo
    67 people viewed this question
    Top Adaptec Computers & Internet Experts
    Robert Graf
    Alun Cox
    Timothy Van Der...
    Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
