Question about Black & Decker 22" Electric Hedge Trimmer
Does not run
My electric trimmer does not run for long so when i turn it off it does it wont start again and it smell like something is brunning.
    Scholar:
  • 76 Answers
With out seeing the trimmers it is a little difficult to tell but with process of elimination - you may want to check the blades to see if the bolts on the blades are to tight there should be very little play so the blades move freely, that wold cause it to heat up, or you may have a short in the wiring which could also cause it to heat up. For the wiring you will have to take the handle and housing apart. If you have to take it apart take your time and lay everything out in order that you take it apart so that all you have to do is go in reverse order to put it all back. Any problems or questions feel free to ask and I will gladly help.
Posted on Jan 14, 2009
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
Sep 25, 2013 | Troy-Bilt Garden
Why is lawn tractor crankshaft pulley smoking
Sounds like something is binding. or belt is slipping. Does it smoke when not in gear. Check and see if everything turns by hand when out of gear and no motor running. Make sure its not binding anyplace. If that is ok Start it up and just idle the engine and try to run the deck and put it in gear. If that stalls it out then you do have a problem.
Jul 09, 2013 | Murray Garden
My 1995 Buick Park Avenue drives fine but randomly starts coughing and spitting as if it's running out of gas, then it breaks down. When this happens the windows lose 99% of their power. When I'm trying to...
they are probably right,its a common problem, the smell is from you loading the battery and starter and cables by constantly cranking engine, the windows on many of those cars have binding tracks so just the battery wont move them as fast as with the alternator going sounds crazy be so ture, good luck,ps. dont take a genius to test that fuelpump,they hopefuly have, good luck .
Nov 03, 2009 | 1995 Buick Park Avenue
Homelite Mighty Lite won't run but a few seconds
Check your muffler to be sure doesn't have a build up of carbon from the oil/gas fuel. This is the problem with 99% of equipment that uses mixed gas. Take the muffler off and see if it runs better without it. If so there is carbon build up in the muffler and muffler port on the engine. Burn the muffler in an open fire for a while to remove the carbon, or burn it with a torch, toss out the screen that's is in most mufflers, (unless of course you live in California where they are required), Scrape out the port with a knife and after the muffler cools on it's own (don't cool with water as you will warp it and not get a good seal) reinstall and see if this solves the problem.
Jun 24, 2009 | Homelite Mighty Lite Lawn Trimmer
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Dryer not working but the light is on
Add peanut butter for better taste. lol... but seriously, the dryer should be be disassembled somewhat so that all the chocolate (or the residue it left) can be completely cleaned out. Unplug it of course. Get a can of electrical spray cleaner from an auto parts store and squirt off everything electrical inside.
Mar 02, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Black & Decker 22" Electric Hedge Trimmer Logo
376 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
