Question about 3Com U.S. Robotics Wireless Turbo Multi-Function Access Point 802.11g/b
NO IP or MAC displayed
When opening the configuration utility, IP and MAC are displayed with zero's (0). So every adaptation of the standard settings is impossible as is access to the web-browser page. Other internet connections are working. Solution??
    Problem Solver:
  • 5 Answers
Solution: IP of 0.0.0.0 means your DHCP server is not providing configuration settings to your network card. Reset router/access point by pressing the reset button with your finger, the tip of a pen, or a paper clip for at least 30 seconds. Try again! If this solution doesn't work, try turning off computer, turn off router/AP, and DSL/Cable modem. Turn on devices in reverse order. First power on modem, then router/AP, then computer. Connect to router/AP and see if it provides IP. If this solution doesn't work, your DHCP settings are not configured correctly. See router's manufacturer manual or visit their Web site.
Posted on Jul 28, 2007
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
How i know the IP address assgined to the print server? once this how can I change it?
According to this site http://www.argecy.com/xtnd100s.html it it supports the use of HP's JetAdmin/Web JetAdmin utility which will allow you to configure the IP address as well as other features.
"Features such as full support for HP JetAdmin/Web JetAdmin"
Utility located here:
http://h20338.www2.hp.com/Hpsub/cache/332262-0-0-225-121.html
That same site also has this information about the ExtendView utility which may help you as well.
TROY LAN Administration Tools
  • ExtendView - 32-bit utility allowing most versatility and functionality available in network printing. Ability to view and configure print servers from unlimited number of views and quick and easy Windows IP address assignment are 2 key benefits. Features such as bulk configuration allow configuration changes for multiple print servers with simple steps. Save and restore feature allows a standard configuration to be saved and later recalled to restore same configuration
  • WebView - web based configuration tool allows complete status and configuration changes simply by typing the print server's IP address into a standard web browser
  • NetworkAlert - specialized Windows printer error utility providing proactive notification of printer problems through the use of SNMP traps
  • ExtendNet Connect - serverless (peer-to-peer) printing for Windows 95/98. Excellent tool for small businesses and remote offices
  • ExtendNet Connect NT - performance enhanced port monitor helps to improve the speed of data flow to the printer
Dec 22, 2010 | Troy ExtendNet 100s Print Server
Access routers configuration and wireless filter to edit MAC List to add MAC adress
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then check wireless or wi fi settings you find there MAC filtering or mac security edit that list then save and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 10, 2009 | Computers & Internet
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
2wire wireless connection
Yes !
Wireless zero configuration service should run.
Go to control panel -> Administrative Tools -> Services, then then locate and double-click on Wireless zero configuration.
Change the Startup type to Automatic, and then click on Start. (Apply and OK).
Also you have to check your Wireless network settings configuration -> Internet Protocol (TCP/IP).
If you are using some utility for wireless connection, disable it and try with Windows (standard) wireless connection.
On the end, it might be useful to compare these above settings with the settings on your another computer and find the differences.
Regards.
Mar 28, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
3Com U.S. Robotics Wireless Turbo Multi-Function Access Point 802.11g/b Logo
178 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Håkan Sterner
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
