Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care 2
Washer was running fine up until it just stopped working. I had been in basement and smelled something burning . The washer was not working and a burning smell was all around it. Breakers did not pop. Is the motor no good?
    Novelist:
  • 166 Answers
Peace,
ngafm at your service,
Things wear out! So is life!
Sounds like the belt wore and slipped and broke!
Is there any power to the washer?
How old is the washer?Sounds old.
Only a trained laundry tech can make the electronic diagnoses.
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
I
Posted on Sep 08, 2008
My whirlpool ultimate II washer was working fine and just stopped. I could smell something like wiring getting hot and now it won't do anything. The basket is still full of clothes and water.
remove the frame,pop off the two clips that hold the pump on and pull the pump off of the motor shaft,start the machine,if it runs you have something stuck in the pump.if it does run get a shop vac and remove the water from the tub,then remove the clamps on the hoses just push them down the hose with a pair of plyers then loosen one hose at a time so you can vac out the water,once you have all the water out you can remove the pump and see what's stuck in it,usually,a sock,womens underwear or a metal from a bra.if it's not the pump move the shaft on the motor with the plyers were the pump slides onto,you could have a flat spot on the motor and by moving the motor at the shaft might free it up,i've done this,some motors will run all the time after this or it could stop again on the next load,watch it and see what happens.http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw&feature=pyv&ad=5457341861&kw=washer%20pump
watch video and it will show you how to get at the pump and motor.good luck with your washer
Jan 23, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Smells like motor is burning. during first wash cycle, washer stopped and there was an electrical burning smell??
YOUR WHIRLPOOL WASHER COULD HAVE A MOTOR PROBLEM, IT IS POSSIBLE THAT SOMETHING HAS GOT CAUGHT IN THE MOTORS WINDINGS AND SHORTED IT OUT. IT YOU CAN STILL HEAR THE MOTOR RUNNING BUT THERE IS NO AGITATION IT COULD BE THAT YOUR DIRECT DRIVE COUPLER NEEDS TO BE REPLACED, PART NUMBER IS 285753. THIS IS A COMMON PROBLEM, ESPECIALLY WHEN THE WASHER IS OVERLOADED AND CAN CAUSE A BURNING SMELL SINCE THIS PART IS RUBBER AND PLASTIC. IF YOUR WASHER IS MAKING ANY SORT OF BANGING NOISE THIS COULD BE THE PROBLEM. YOU CAN CHECK THIS BUT IT DOES INVOLVE REMOVING THE PUMP AND MOTOR. ANOTHER POSSIBLE PROBLEM IS THAT THERE IS SIMPLY A BURNED CONNECTION ON YOUR UNITS ELECTRICAL SYSTEM AND IF IT CANNOT BE REPAIRED IT WILL HAVE TO BE REPLACED.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitating, ticking noise and then burning rubber smell
HI, the motor is failing slowly and, i recommend replacing this damaged motor asap before it starts to over heat and present a fire hazard.
Jun 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Funky smell from working Whirlpool Ultimate Care II
run the washer then smell the motor or see if anything has jumped the tub and causing the clutch to pull harder
Mar 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal De
