Question about Maytag PAV2300 Top Load Washer
Won't spin all other functions work properly
PROBLEM started 2 months ago. soltion used other cycle ... worked fine till now
  • 1 more comment
  • Anonymous Sep 10, 2008
    I have the same issue. Will start normally, fill, agitate, but will not spin. If I reset the selector to spin it will then cycle.
    At a total loss on where to begin.
  • heathergwood Sep 13, 2008
    Our Maytag Performa PAV2300 will not spin fast enough to drain all of the water. Any suggestions on what might be causing this would be appreciated!
  • Anonymous Oct 18, 2008
    maytag performa pavt234aww
  • 943 Answers
Hi thanks for the question the washer does not spin to pump the water out first it has to pump the water out in your case i would check the drain hose make sure theres no obstruction thanks the appliance doc
Posted on Sep 26, 2008
Pye2200ay won start
Is the plastic locater lug on the door that makes contact with the switch... intact and making breaking the switch properly?
Also check the switch mechanism to see if it is functioning correctly
This could be your problem if you say everything works ok. when you part the wires of the switch.
you may need to replace one or the other or both if you can remove the door switch take it to a shop that sells parts and ask them to confirm it is working.
You could also ask if you could see a plastic lug off the door then you will know if that could be faulty also?
Best of luck!
Jun 15, 2013 | Maytag PYE2300AY Electric Dryer
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
Wont fill or spin runs dry
Check the water pressure switch for proper operation
Oct 19, 2009 | GE WBSE3120B Top Load Washer
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
GE WASHER WWSE6260B2WW
The most common reason a GE washer will not spin is that the water level tube has a bunch of goo in it. When the washer pumps out, the air does not escape past the goo, and the washer thinks it is still full of water, and thus it will not send power to the motor to spin.
Pop the front off the machine with a putty knife at the front top seam and pull the clear tube off the left front side of the outer tub. Usually it is easiest to just cut off the first inch of the tube (where the goo is) and reattach, however you may want to clean the tube end and the hollow nipple it attaches to with a thin wire. This problem is seen most often with consumers who rarely if ever use liquid bleach. If you don't use bleach very often, filling to the lowest water setting with the hottest water possible, and a strong concentration of liquid bleach, then running the washer through a cycle (no clothes) every 6 month or so should prevent the problem from reoccouring.
Aug 16, 2008 | GE Profile WPSR3120WWW
Maytag PAV2300 Top Load Washer Logo
154 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
