Question about Black & Decker Blower Vacuum Mulcher 1 Ea
Power hog does not want to turn on I do have power just wondering if it is the brushes
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
What could be the problem?
I beleive that is a universal motor with brushes. It sounds like one of the brushes is not in contact with the comutator. Be carefull, that can do a lot of damage to a human body.
Aug 24, 2014 | Black & Decker Garden
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
5 ' brush hog boggs down when attempting to mow & one blade hits underdeck in one place
sounds like that blade is bent also if they are dull it will bog down more
Jul 05, 2012 | Garden
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
The brush isn't turning to clean carpet wondered if it has a belt that controls that
It has a series of gears inside of it. sometimes they get dirty and won't move. take the bottom off and clean it. It is actually powered by the suction of the motor.
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Leaf Hog trouble
The carbon brushes wear out after a few years .B&D does not carry replacements . I took out one of the old brushes and found an exact replacement at an electronics parts surplus store . The replacement didn't have the little endcap on it so I used the ones from the old brushes and pigtailed the connector wire .
Its been working fine since !
Oct 22, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Lawn hog electric mower
Sounds like the brushes are bad .or you have a direct short.
Aug 30, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Blower Vacuum Mulcher 1 Ea Logo
53 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
